Introduction
The buttons on the adapter are glued to a rubber mold within the adapter. It will take patience to scrape away this glue without damaging the rubber mold.
Ce dont vous avez besoin
Insert the flat edge of a metal spudger in the seam between the adapter body and the plastic casing. Move the spudger into one of the corners.
Push down on the spudger to separate the casing from the adapter until you hear a click and the casing stays open on that side.
Do the same to the other side until the casing comes off.
