Aller au contenu principal
Xbox One Stereo Headset Microphone Replacement
Ce dont vous avez besoin
  1. Xbox One Stereo Headset Microphone Replacement, Microphone: étape 1, image 1 de 3 Xbox One Stereo Headset Microphone Replacement, Microphone: étape 1, image 2 de 3 Xbox One Stereo Headset Microphone Replacement, Microphone: étape 1, image 3 de 3
    • Use the flat end of a spudger to pry out the rubber stopper at the base of the boom.
  2. Xbox One Stereo Headset Microphone Replacement: étape 2, image 1 de 1
    • Remove the single 6 mm flathead #2.0 screw exposed after removing the rubber stopper.
  3. Xbox One Stereo Headset Microphone Replacement: étape 3, image 1 de 1
    • Lift the joint of the boom up and over its pivot point to separate the microphone from the headset.
  4. Xbox One Stereo Headset Microphone Replacement: étape 4, image 1 de 3 Xbox One Stereo Headset Microphone Replacement: étape 4, image 2 de 3 Xbox One Stereo Headset Microphone Replacement: étape 4, image 3 de 3
    • Using the flat end of the metal spudger, pry the back plate off the boom.
    • The back plate is glued to the boom and must be removed gently.
    • When re-installing, apply a few drops of super glue to hold it in place.
  5. Xbox One Stereo Headset Microphone Replacement: étape 5, image 1 de 1
    • Pull the back plate off the boom.
  6. Xbox One Stereo Headset Microphone Replacement: étape 6, image 1 de 1
    • Using the flat end of the plastic spudger, gently pry the microphone out of its casing.
    • Desolder the two wires from the back of the microphone. For instructions on how to solder and desolder, please see the soldering technique guide.
    • The white wire connects to the positive node, which is indicated with a "+" on the microphone.
4 autres ont terminé cette réparation.
Trevor Steele
Membre depuis le 02/01/15
233 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-37, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 membres
5 tutoriels rédigés
9 commentaires
Is a replacement microphone available from iFixit?
Scott Minton - Réponse
What do you replace the mic with?
Its Me - Réponse
They have the microphone for sale
daniel david guerrerogarcia - Réponse
Would it presumably be just as easy to replace the microphone speaker with one from another headset, granted it fits ?
harumscxarum - Réponse
Any mod to make the cable removable?
kikis.andcream - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 33
Total : 23,921
