Aller au contenu principal
Xbox One Stereo Headset Speaker Replacement
Ce dont vous avez besoin
  1. Xbox One Stereo Headset Speaker Replacement, Speaker: étape 1, image 1 de 1
    • Firmly grip the ear pad and the plastic back plate underneath. With your other hand, grip the back of the speaker casing.
    • Do not grip the back of the speaker by the headband. Twisting this connection will break the headphone off the headband.
    • With the ear pad facing you, push down on the back plate and turn counter-clockwise to unlock the prongs holding it in place. The back plate will only rotate about 1 cm.
  2. Xbox One Stereo Headset Speaker Replacement: étape 2, image 1 de 1
    • Lift the back plate (with the ear pad attached) straight up from the speaker.
    • This should be very easy to do. If it doesn't come off easily, then the plate isn't fully rotated.
  3. Xbox One Stereo Headset Speaker Replacement: étape 3, image 1 de 1
    • Remove three 7 mm Phillips #00 screws holding the speaker in place.
  4. Xbox One Stereo Headset Speaker Replacement: étape 4, image 1 de 1
    • Carefully open the back casing, exposing the speaker wires.
  5. Xbox One Stereo Headset Speaker Replacement: étape 5, image 1 de 1
    • Use wire cutters to cut the blue and black wires from the headset close to where they are spliced to the red and black wires from the speaker.
    • Splice the headset wires to the corresponding replacement speaker wires.
    • Black connects to black, red connects to blue.
    • Although soldering isn't necessary when splicing wires, doing so creates a more reliable connection.
12 autres ont terminé cette réparation.
Shannon Prouty
Membre depuis le 01/30/15
781 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 17-37, Amido Winter 2015 Membre de l'équipe Cal Poly, Team 17-37, Amido Winter 2015
CPSU-AMIDO-W15S17G37
4 membres
5 tutoriels rédigés
3 commentaires
what part is using to hold the speaker in place that you can adjust to fit your head
Nicholas Ryver - Réponse
where can I buy the replacement speaker ?
Juan Carlos Sánchez Pulido - Réponse
Can some help me with fixing a earmuff detached from the head band but the wires are still attached
Harry Obrastsoff-Rutinsky - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 34
Total : 12,685
