Aller au contenu principal
Xbox One Wireless Controller 1697 Thumbstick Replacement
Ce dont vous avez besoin
  1. Xbox One Wireless Controller 1697 Thumbstick  Replacement, Thumbstick: étape 1, image 1 de 1
    • Slide the battery pack cover toward the top of the controller to remove it.
    • Remove batteries.
  2. Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 2, image 1 de 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 2, image 2 de 2
    • We recommend using a plastic spudger to prevent damage to your controller. However, using a metal spudger, as shown in the picture, makes the work easier.
    • Hold firmly the controller, place the spudger into the top seam of the controller and carefully work all the way to the bottom.
    • Pry the side of handle away from the controller by moving the spudger back and forth around the side handle's seam.
    • Repeat this process for both side handles.
  3. Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 3, image 1 de 2 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 3, image 2 de 2
    • Using the T8 Security Torxs screwdriver, remove the five 10mm screws from the back of the controller.
    • One of the screws is hidden behind the label.
    • You can punch a hole using a screwdriver or peel off the label.
  4. Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 4, image 1 de 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 4, image 2 de 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 4, image 3 de 3
    • Remove the back plate.
  5. Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 5, image 1 de 1
    • Remove the faceplate
  6. Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 6, image 1 de 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 6, image 2 de 3 Xbox One Wireless Controller 1697 Thumbstick  Replacement: étape 6, image 3 de 3
    • Select the thumbstick that you want to replace and pull it off its pole.
28 autres ont terminé cette réparation.
Emely
Membre depuis le 09/27/17
866 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S9-G1, Remmell Fall 2017 Membre de l'équipe USF Tampa, Team S9-G1, Remmell Fall 2017
USFT-REMMELL-F17S9G1
4 membres
14 tutoriels rédigés
1 commentaire de tutoriel
Hello. I have an controller but it isn't working right. The right stick wont register when i push it down. I spilled cola on it. Any tips?
Isak - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 48
30 derniers jours : 214
Total : 26,269
