Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will teach you how to remove the buttons.
  1. Remove the battery pack cover.
    • Remove the battery pack cover.
    • Remove batteries.
  2. We recommend using a nylon spudger for this step. A metal spudger is shown. Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • We recommend using a nylon spudger for this step. A metal spudger is shown.
    • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
    • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
  3. There is a hidden screw located in the middle of the controller behind the label. Use a screwdriver and punch a hole directly in the center of the label.
    • There is a hidden screw located in the middle of the controller behind the label.
    • Use a screwdriver and punch a hole directly in the center of the label.
    • You may also lift the label if you do not want to puncture it.
    • Remove the five 10mm screws located on the back of the controller using the T8 Security Torx Screwdriver.
  4. Remove the backplate.
    • Remove the backplate.
  5. Remove the faceplate.
    • Remove the faceplate.
  6. You may let the rumble motors hang freely out of their sockets. De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • You may let the rumble motors hang freely out of their sockets.
    • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
    • De-solder the black and gray wires that are attached to the top motherboard.
    • Remove the rumble motors and set them aside.
    • Be careful while using the soldering iron not to damage other components or hurt yourself.
    • For information on how to solder, click here.
  7. Unscrew the two 7mm T6 screws located near the rumble motor sockets.
    • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
  8. Firmly grip sides of motherboard near the middle.
    • Firmly grip sides of motherboard near the middle.
    • Lift upwards while slightly wiggling the motherboard forward and backward.
    • Lifting the motherboard will require some force.
  9. Remove the six T6 Torx screws located on the bottom motherboard. Remove the six T6 Torx screws located on the bottom motherboard.
    • Remove the six T6 Torx screws located on the bottom motherboard.
  10. Remove the bumpers by prying them off of the pegs that secure them, using a spudger.  They are located on the front and back of the controller. A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
    • Remove the bumpers by prying them off of the pegs that secure them, using a spudger. They are located on the front and back of the controller.
    • A standard nylon spudger is recommended for this step. Using a metal spudger near the motherboard as shown risks damaging your device.
  11. Lift the piece surrounding the Home button off of its pegs. Pry it off of the other side, using a spudger on the pins.
    • Lift the piece surrounding the Home button off of its pegs.
    • Pry it off of the other side, using a spudger on the pins.
    • Removing this piece may require a lot of force.
  12. Remove the bottom motherboard.
    • Remove the bottom motherboard.
  13. Remove the rubber backing to the buttons.
    • Remove the rubber backing to the buttons.
  14. With the buttons facing down, push them up out of their housings, and remove.
    • With the buttons facing down, push them up out of their housings, and remove.
86 autre(s) ont terminé cette réparation.
Garrett George
Membre depuis le 22/01/2015
5 057 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 20-15, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 20-15, Maness Winter 2015
CPSU-MANESS-W15S20G15
5 membres
47 tutoriels rédigés
28 commentaires
do you have a URL for the repair parts (rubber pads) ect. for the wireless controllers
kendixon69 - Réponse
For all of my Xbox One controllers, I needed the tamper-resistant Torx bits. They're the ones with the hole in the center, like these: http://www.amazon.com/Pro-Grade-13pc-Tam.... Any tamper-resistant or Torx security bit set should do as long as it has the sizes listed in the Tools section of this FixIt article.
Frank Wilson - Réponse
Just an FYI you can use a flat screwdriver against the post and side and it will either work or break the post which is what happened to me and allowed me to use a normal torx screwdriver.
sid f -
Looking to replace the switch on the right bumper, can't find any parts or numbers. Looking for help please.
sid f - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 126
7 derniers jours : 824
30 derniers jours : 4,214
Total : 410,236
