Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox One Wireless Controller Model 1537 Analog Sticks Replacement
Ce dont vous avez besoin
    1. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Battery Pack: étape 1, image 1 de 1
      • Remove the battery pack cover.
      • Remove batteries.
      Demander à FixBot
      Ajouter un commentaire
    2. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Side Handles: étape 2, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Side Handles: étape 2, image 2 de 2
      • We recommend using a nylon spudger for this step. A metal spudger is shown.
      • Grip the controller firmly to remove the side handles, wedging a spudger into the seam between the front and handle plates.
      • Pry the side plate away from the front plate by moving the spudger back and forth. You will need to do this all the way around the side plate's seam.
      Demander à FixBot
    3. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Screws: étape 3, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Screws: étape 3, image 2 de 2
      • There is a hidden screw located in the middle of the controller behind the label.
      • Use a screwdriver and punch a hole directly in the center of the label.
      • You may also lift the label if you do not want to puncture it.
      • Remove the five 10mm screws located on the back of the controller using the TR8 Security Torx Screwdriver.
      Demander à FixBot
    4. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Backplate: étape 4, image 1 de 1
      • Remove the backplate.
      Demander à FixBot
    5. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Faceplate: étape 5, image 1 de 1
      • Remove the faceplate.
      Demander à FixBot
    6. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Top Motherboard: étape 6, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Top Motherboard: étape 6, image 2 de 2
      • You may let the rumble motors hang freely out of their sockets.
      • De-solder the soldered joints while holding the red and black wires down on the top motherboard.
      • De-solder the black and gray wires that are attached to the top motherboard.
      • Remove the rumble motors and set them aside.
      • Be careful while using the soldering iron not to damage other components or hurt yourself.
      • For information on how to solder, Click Here
      Demander à FixBot
    7. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement: étape 7, image 1 de 1
      • Unscrew the two 7mm T6 screws located near the rumble motor sockets.
      Demander à FixBot
    8. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement: étape 8, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement: étape 8, image 2 de 2
      • Firmly grip sides of motherboard near the middle.
      • Lift upwards while slightly wiggling the motherboard forward and backward.
      • Lifting the motherboard will require some force cause there's connections.
      Demander à FixBot
    9. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Cleaning & Flux: étape 9, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Cleaning & Flux: étape 9, image 2 de 2
      • if there's any corrosion or rust on the pads clean that before you continue.
      • if you want you can apply flux to help with soldering but it is not needed.
      • do the same for the other side
      Demander à FixBot
    10. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Desoldering: étape 10, image 1 de 3 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Desoldering: étape 10, image 2 de 3 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Desoldering: étape 10, image 3 de 3
      • you can use a desoldering iron,solder sucker or a copper wick
      • remove all the solder.
      • if there's any left you can resolder those points and try again
      Demander à FixBot
    11. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Removal: étape 11, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Removal: étape 11, image 2 de 2
      • check to make sure all the points are loose.
      • pull the analog stick down.
      Demander à FixBot
    12. Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Resoldering: étape 12, image 1 de 2 Xbox One Wireless Controller Model 1537 Analog Sticks Replacement, Resoldering: étape 12, image 2 de 2
      • resolder the pads and make sure to get it on the correct side of the board
      • the solder joints should look like the second image
      Demander à FixBot
archer horst
Membre depuis le 04/29/26
373 Réputation
2 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 62
30 derniers jours : 273
Total : 897
