Introduction
This guide will show you how to access and replace the top motherboard. Soldering is required, so the link to the soldering guide is included to help you.
Slide the battery cover toward the top of the controller to remove it.
Lift up the batteries or the battery pack from the battery compartment.
Tape the Rumbler/shock motors in place.
This will prevent the motors from falling out.
Turn the device over and remove the directional pad by gently pulling it away from the controller.
Turn the device over and remove the two 7.0mm torx-6 screws in the bottom left and right corners.
Firmly grasp the top and bottom motherboards in opposite hands, then gently pull them apart.
19 autres ont terminé cette réparation.
