Introduction
This is a prerequisite-only guide! This guide is part of another procedure and is not meant to be used alone.
Follow this guide to remove the lower metal case on the Xbox One X model 1787. This is necessary for accessing the console’s inner components. Turn off your console and disconnect any cables before starting this guide.
Ce dont vous avez besoin
Use blunt tweezers to peel off the sticker covering the right-side screw on the back of the console.
Use a T10 Torx screwdriver to remove the two 12.6 mm–long screws located on the back of the console.
Rotate the console 90 degrees.
Pull the front of the upper plastic case horizontally toward the front of the console until it comes to a stop. This slides the clips out of the slots on the upper plastic case.
Rotate the console 90 degrees so that the back is facing you.
Lift up the left side of the upper plastic case (as viewed from the back of the console), stopping when it won’t lift any further.
Use the pointed end of a spudger, an opening tool, or your fingernail to flip down the small, hinged locking flap on the ribbon cable ZIF connector on the front circuit board.
Use blunt tweezers to pull the ribbon cable down out of the connector.
Use a T8 Torx screwdriver to remove the three 13.3 mm screws securing the front circuit board to the upper metal case.
Pull the front circuit board straight out away from the upper metal case and set it aside.
Use a T10 Torx screwdriver to remove the six 47.7 mm screws securing the upper metal case to the lower plastic case.
Use a T8 Torx screwdriver to remove the two 7.5 mm screws securing the press connector to the upper metal case.
Insert the flat end of a spudger underneath the press connector on the side opposite of the ribbon cable.
Use the spudger to lift the press connector up and away from the upper metal case.
Flip the console over.
Lift the lower plastic case up from the metal case and set it aside.
Remove the two T10 Torx screws securing the lower metal case:
One 7.7 mm screw
One 11.4 mm screw
Lift the lower metal case up off the upper metal case and internal components.
Set the lower metal case aside.
