Introduction
Use this guide to replace the damaged or worn-out thumbstick covers on your Xbox Series X|S Controller (model 1914).
Thumbstick covers are sometimes called joystick covers, joystick toppers or thumbstick toppers.
Ce dont vous avez besoin
Use your fingers to slide up and remove the battery cover.
Insert an opening tool between the left handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the left handle cover and pry intermittently to release the plastic clips.
Pry up the middle inner edge of the handle cover with the opening tool to release the remaining clips.
Remove the left handle cover.
Insert an opening tool between the right handle cover and the bottom inner edge of the back housing.
Slide the opening tool along the inner edge of the right handle cover and pry intermittently to release the plastic clips.
Remove the right handle cover.
Outil utilisé dans cette étape :Tweezers$4.99
Use a pair of tweezers or your fingers to peel back the sticker to reveal the screw.
Use a Torx T8 Security driver to remove the five 9.3 mm-long screws securing the top housing, three near the top and two at the bottom.
14 autres ont terminé cette réparation.
2 commentaires
This was really helpful in fixing my thumbsticks. The only suggestion I have is to remove the battery cover after you're removed the handle covers instead of before. It will be easier to grip the controller while using the pry tools when the battery cover is still on.
Replaced the right thumb stick after mine broke. 3d printed a new stick and seems to be working fine. Thanks
