Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement
Ce dont vous avez besoin
  1. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Uncover the back panel screws: étape 1, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Uncover the back panel screws: étape 1, image 2 de 2
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 2, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 2, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 2, image 3 de 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of tweezers or a sharp blade to peel up a corner of the large sticker on the back panel. Use your fingers to peel it farther, just enough to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the back panel screws: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unclip the back panel: étape 4, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unclip the back panel: étape 4, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unclip the back panel: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 5, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 5, image 2 de 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the back panel: étape 6, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the back panel: étape 6, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the back panel: étape 6, image 3 de 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 7, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 7, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 7, image 3 de 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the fan screws: étape 8, image 1 de 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the fan cable: étape 9, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the fan cable: étape 9, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the fan cable: étape 9, image 3 de 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the fan: étape 10, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the fan: étape 10, image 2 de 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unlatch the base: étape 11, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unlatch the base: étape 11, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Unlatch the base: étape 11, image 3 de 3
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Twist and remove the base: étape 12, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Twist and remove the base: étape 12, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Twist and remove the base: étape 12, image 3 de 3
    • Grip the base and rotate it counterclockwise to unlock it from the shell.
    • You may need to hold the locking tab open while you get the base started.
    • Remove the base.
    • During reassembly, drop the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the optical drive screws: étape 13, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the optical drive screws: étape 13, image 2 de 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the vibration isolator: étape 14, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the vibration isolator: étape 14, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the vibration isolator: étape 14, image 3 de 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power and data cables: étape 15, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power and data cables: étape 15, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power and data cables: étape 15, image 3 de 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the optical drive: étape 16, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the optical drive: étape 16, image 2 de 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the USB port cable: étape 17, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the USB port cable: étape 17, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the USB port cable: étape 17, image 3 de 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 18, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement: étape 18, image 2 de 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power button cable: étape 19, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power button cable: étape 19, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Disconnect the power button cable: étape 19, image 3 de 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the chassis screws: étape 20, image 1 de 1
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Peel up the USB port cable: étape 21, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Peel up the USB port cable: étape 21, image 2 de 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the center chassis assembly: étape 22, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the center chassis assembly: étape 22, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the center chassis assembly: étape 22, image 3 de 3
    • The center chassis is aligned to the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the center chassis and pull it towards the green fan grille at the top of the shell, uncoupling the guide pegs from the shell.
    • Lift out the center chassis assembly to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the antenna board screws: étape 23, image 1 de 2 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the antenna board screws: étape 23, image 2 de 2
    • Use a T8 Torx driver to remove the three 9.6 mm‑long screws securing the antenna board to the center chassis.
  24. Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the accessory antenna board: étape 24, image 1 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the accessory antenna board: étape 24, image 2 de 3 Xbox Series X 2TB Galaxy Black Accessory Antenna Board Replacement, Remove the accessory antenna board: étape 24, image 3 de 3
    • Grip the top right corner of the antenna board and pull it directly away from the center chassis to disconnect it.
    • During reassembly, align the board's connector with the port on the center chassis and press to reconnect.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
2 autres ont terminé cette réparation.
Spencer Day
Membre depuis le 09/14/22
169 400 Réputation
1 086 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
124 membres
24 344 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 15
30 derniers jours : 39
Total : 495
