Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement
Ce dont vous avez besoin
  1. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Uncover the back panel screws: étape 1, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Uncover the back panel screws: étape 1, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Uncover the back panel screws: étape 1, image 3 de 3
    • Before you begin, completely power down and unplug all cables from your console.
    • Use a pair of tweezers to remove the sticker hiding the first screw on the back panel, near the base.
  2. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 2, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 2, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 2, image 3 de 3
    • For cleaner removal, use an iOpener or hair dryer to heat the sticker.
    • Use a pair of blunt tweezers to peel back the large sticker on the back panel to reveal the second screw.
    • You only need to peel this sticker to where you can access the hidden screw. You don't need to pull it completely off.
    • Technically, these are tamper-evident stickers, but don't worry—Microsoft can't legally void your warranty, as long as you don't damage anything. Have fun!
  3. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the back panel screws: étape 3, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the back panel screws: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    • Use a T8 Torx driver to remove the two 7.4 mm‑long screws securing the back panel.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your console.
  4. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Unclip the back panel: étape 4, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Unclip the back panel: étape 4, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Unclip the back panel: étape 4, image 3 de 3
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the left side of the base.
    • Pry up the back panel to release it from the locking clips.
  5. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 5, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 5, image 2 de 2
    • Insert the flat end of a spudger into the gap between the back panel and the shell, near the right side of the base.
  6. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the back panel: étape 6, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the back panel: étape 6, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the back panel: étape 6, image 3 de 3
    • Grip the back panel at the opening you just created and pull it up and away from the shell to unclip the long edges.
    • During reassembly, press along the edges of the back panel to snap it into place.
  7. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 7, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 7, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 7, image 3 de 3
    • The back panel slots into a gap at the top of the shell.
    • Tilt the back panel up and pull it away from the top edge of the shell to release it from the gap.
    • Remove the back panel.
  8. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the fan screws: étape 8, image 1 de 1
    • Use a T8 Torx driver to remove the three screws securing the fan to the center chassis:
    • One 10.5 mm pancake screw
    • Two 8.8 mm screws
  9. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the fan cable: étape 9, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the fan cable: étape 9, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the fan cable: étape 9, image 3 de 3
    • Use your fingers or a pair of blunt tweezers to grip the edges of the fan cable connector, and pull up to disconnect it from the center chassis.
    • Always pull cables by their connectors and not the wires themselves.
    • During reassembly, route the fan cable underneath its small cable guide on the fan housing so it doesn't interfere with the back panel.
  10. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the fan: étape 10, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the fan: étape 10, image 2 de 2
    • Slide the fan out of its slot to remove it.
    • During reinstallation, note that the fan can only be installed one way—make sure Master Chief is facing you.
    • If you're replacing the fan, a new fan might not include the plastic installation bracket, which is attached to the fan with four T10 Torx screws. This isn't pictured in this guide.
  11. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Unlatch the base: étape 11, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Unlatch the base: étape 11, image 2 de 2
    • Use the flat end of a spudger to lift up on the locking tab holding the base to the shell.
  12. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Twist and remove the base: étape 12, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Twist and remove the base: étape 12, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Twist and remove the base: étape 12, image 3 de 3
    • With the locking tab held open, grip the base and rotate it counterclockwise to unlock it from the shell.
    • Remove the base.
    • During reassembly, put the base tabs into their holes on the shell and twist clockwise until the base snaps into the interior locking tab.
    • When locked in place, the "Hello from Seattle" line will be parallel with the device's sides.
  13. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the optical drive screws: étape 13, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the optical drive screws: étape 13, image 2 de 2
    • Use a T8 Torx driver to remove the two 8.8 mm screws securing the optical drive's vibration isolator to the shell: one on the base and one on the top of the isolator.
  14. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the vibration isolator: étape 14, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the vibration isolator: étape 14, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the vibration isolator: étape 14, image 3 de 3
    • Lift up the optical drive's vibration isolator to remove it.
    • The vibration isolator grips the sides of the optical drive with silicone pads, so you may need to "walk" the isolator off of the drive to slip it off each side.
    • During reassembly, ensure the vibration isolator is pushed down and around both edges of the optical drive, so it sits flush with the rest of the center chassis.
  15. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power and data cables: étape 15, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power and data cables: étape 15, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power and data cables: étape 15, image 3 de 3
    • Use a pair of blunt tweezers to grip the edges of the optical drive power connector and pull up to disconnect it from the optical drive.
    • Use your fingers to pull up and disconnect the data cable from the optical drive.
  16. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the optical drive: étape 16, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the optical drive: étape 16, image 2 de 2
    • Grip the top edge of the optical drive and pull it out of its slot in the shell to remove it.
    • During reassembly, align the pegs on the bottom edge of the optical drive with the guide holes on the bottom of the shell.
    • If the drive is misaligned, the top vibration isolator will not be able to be installed correctly, and the disc reader will be misaligned with the front of the console.
  17. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: étape 17, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: étape 17, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Xbox Series X 2TB Galaxy Black Chassis Removal: étape 17, image 3 de 3
    • The ribbon cables and their connectors are extremely fragile, so always open locking tabs gently and pull cables slowly.
    • Use the flat end of a spudger to flip open the metal locking tab on the USB port ribbon cable.
    • During reassembly, gently snap the metal locking tab back into place once the cable has been inserted.
  18. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 18, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 18, image 2 de 2
    • Use a pair of tweezers to pull up on the black plastic pull tab to disconnect the USB port cable.
    • Pull only on the pull tab, not the cable itself.
    • If the USB port cable feels adhered to the metal chassis, use an apply an iOpener or hair dryer to heat the cable. Depending on your model of Xbox, you may also need to slide an opening pick under the cable to separate the adhesive.
  19. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power button cable: étape 19, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power button cable: étape 19, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Disconnect the power button cable: étape 19, image 3 de 3
    • Use the pointed end of a spudger to depress the metal tab on the side of the power button cable's board connector.
    • With the metal tab depressed, use a pair of tweezers to pull up on the pull tab to disconnect the power button cable from the center chassis.
    • Don't pull on the cable without depressing the metal tab, otherwise you risk damaging either the cable or the connector.
    • During reassembly, the cable should lightly "snap" into place when inserted.
  20. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the chassis screws: étape 20, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the chassis screws: étape 20, image 2 de 2
    • Use a T8 Torx driver to remove the three 7.4 mm screws securing the center chassis assembly to the shell.
  21. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 21, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 21, image 2 de 2
    • Gently peel the taped USB port ribbon cable off of the heatsink.
    • Depending on your model of Xbox, the adhesive may be on the underside of the cable. If so, use an iOpener or hair dryer to heat the cable.
  22. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 22, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 22, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 22, image 3 de 3
    • The center chassis assembly is aligned to the bottom of the shell with guide pegs. These pegs will need to slide out of their slots to allow the chassis to be lifted out.
    • Grip the chassis and pull it towards the top of the shell, uncoupling the guide pegs from the shell.
    • Use two hands to lift out the chassis to remove it from the shell.
    • During reassembly, make sure neither of the ribbon cables get pinched as you lower the center chassis into the shell.
  23. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 23, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 23, image 2 de 2
    Dust Blower
    $5.99
    • Gently place the chassis heatsink-side down on a clean work surface.
    • During reassembly, this is a good point to clean the heatsink fins of any dust, dirt, or debris that may have built up over time. Use a dust blower or compressed air to clear out the fins.
  24. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Separate the USB board cable: étape 24, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Separate the USB board cable: étape 24, image 2 de 2
    • The USB board cable is adhered to the shell with pieces of mild adhesive.
    • Use an iOpener or a hair dryer to heat the USB board cable.
  25. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 25, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 25, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement: étape 25, image 3 de 3
    iFixit Opening Picks (Set of 6)
    • Be very careful when lifting the cable where it connects to the board. Peel gently, and slide an opening pick under the cable if you're having trouble separating the adhesive.
    • Use your fingers to peel up the USB board cable and fully separate it from the shell.
    • During reassembly, use thin double‑sided adhesive to secure the cable. If there's adhesive left and it's still sticky, you can reuse it. If you have a new cable, check it for pre‑installed adhesive and remove any liners.
  26. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure screws: étape 26, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure screws: étape 26, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure screws: étape 26, image 3 de 3
    • Use a T8 Torx driver to remove the two 8.9 mm‑long screws securing the USB board enclosure:
    • One screw inside the shell
    • One screw on the bottom of the shell (where the base was)
  27. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure: étape 27, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure: étape 27, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB enclosure: étape 27, image 3 de 3
    • Use your fingers to slide the USB board enclosure out from under the metal clip securing it to the shell.
    • Remove the enclosure.
    • During reassembly:
    • Make sure the Pair button is properly oriented and fully inserted in its slot.
    • Firmly slide the enclosure into position until it snaps into place under the metal clip.
  28. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB board screws: étape 28, image 1 de 2 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB board screws: étape 28, image 2 de 2
    • Use a T8 Torx driver to remove the four 8.9 mm‑long screws securing the USB board to its enclosure.
  29. Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB board: étape 29, image 1 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB board: étape 29, image 2 de 3 Xbox Series X 2TB Galaxy Black USB and Pair Button Board Replacement, Remove the USB board: étape 29, image 3 de 3
    • Use your fingers to lift the skinnier side of the board.
    • Pull the board away from the enclosure and out from under its clips to remove it.
    • Check if your replacement board comes with a cable. If it doesn't, remove the cable from your original board and transfer it to your replacement.
    • During reassembly, first insert the board under its clips on the wider edge of the enclosure and then lay the board into place.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Xbox Series X Answers community for help.
Spencer Day
Membre depuis le 09/14/22
169 400 Réputation
1 087 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
124 membres
24 345 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 18
Total : 238
