Aller au contenu principal
Xiaomi Mi 3 Side control buttons Replacement
Ce dont vous avez besoin
  1. Xiaomi Mi 3 Side control buttons Replacement, Battery: étape 1, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement, Battery: étape 1, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement, Battery: étape 1, image 3 de 3
    • Firmly press the SIM card removal tool into the hole located at the top of the phone to eject the SIM card tray from the slot.
  2. Xiaomi Mi 3 Side control buttons Replacement: étape 2, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement: étape 2, image 2 de 2
    • Remove the two Phillips head screws located at the top of the phone on either side where the SIM card was ejected.
    • One screw is located under an orange sticker which would serve as your warranty for the camera were this practice not illegal as per the Magnuson–Moss Warranty Act of 1975.
  3. Xiaomi Mi 3 Side control buttons Replacement: étape 3, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 3, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 3, image 3 de 3
    • Insert a pry tool into the upper edge of the phone, where there is a small gap between screen and frame of the phone to begin separating the screen from the rest of the phone.
    • Be careful when using the pry tool as it can damage the phone's screen or other components.
  4. Xiaomi Mi 3 Side control buttons Replacement: étape 4, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 4, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 4, image 3 de 3
    • Once the pry tool has been inserted into the phone, slide it around the perimeter of the phone while gently lifting until the screen panel and back panel of the phone separate.
  5. Xiaomi Mi 3 Side control buttons Replacement: étape 5, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement: étape 5, image 2 de 2
    • The back of the phone should now be separated from the screen.
  6. Xiaomi Mi 3 Side control buttons Replacement: étape 6, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 6, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 6, image 3 de 3
    • Place the front panel screen side down with the camera at the top.
    • Remove these six Phillips head screws located at the upper half of the phone.
    • This screw is located under an orange sticker at the top right corner of the panel. The sticker can be removed with a pair of tweezers, then remove that Phillips head screw.
  7. Xiaomi Mi 3 Side control buttons Replacement: étape 7, image 1 de 1
    • Next, remove these three screws located at the bottom of the back panel.
  8. Xiaomi Mi 3 Side control buttons Replacement: étape 8, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement: étape 8, image 2 de 2
    • Using tweezers, remove the rubber dust cover on the back panel of the phone.
  9. Xiaomi Mi 3 Side control buttons Replacement: étape 9, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 9, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 9, image 3 de 3
    • Remove the plastic cover on the bottom of the back panel by inserting the pry tool at the edge and gently lifting.
  10. Xiaomi Mi 3 Side control buttons Replacement: étape 10, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 10, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 10, image 3 de 3
    • Remove the upper plastic cover from the back panel by inserting the pry tool into the upper edge and gently lifting.
    • Some models have the NFC antenna at the back of the battery glued to the top cover. It is not possible to remove the top cover without removing the battery as well. For these models, check the touchscreen guide for instructions.
  11. Xiaomi Mi 3 Side control buttons Replacement: étape 11, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 11, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 11, image 3 de 3
    • Using a spudger, remove the small ribbon cable that is connected to the battery.
  12. Xiaomi Mi 3 Side control buttons Replacement: étape 12, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 12, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 12, image 3 de 3
    • Remove the battery by gripping and pull up on the "Battery Removal" tab attached to the left side of the battery on the back panel.
    • Some force may be required to remove the battery since it is adhered to the phone with two pieces of double sided tape.
  13. Xiaomi Mi 3 Side control buttons Replacement: étape 13, image 1 de 1
    • The battery is now removed from the panel.
  14. Xiaomi Mi 3 Side control buttons Replacement, Motherboard: étape 14, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement, Motherboard: étape 14, image 2 de 2
    • Disconnect the antenna wire that is attached to the lower left side of the motherboard using the pry tool.
  15. Xiaomi Mi 3 Side control buttons Replacement: étape 15, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 15, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 15, image 3 de 3
    • Use a pry tool to separate the LCD display cable from the motherboard. The cable connects to the motherboard as a rectangular metallic piece at the bottom right of the motherboard.
  16. Xiaomi Mi 3 Side control buttons Replacement: étape 16, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement: étape 16, image 2 de 2
    • Disconnect the gold ribbon cable for the LCD display by gently inserting the pry tool under the wide end and lifting up.
  17. Xiaomi Mi 3 Side control buttons Replacement: étape 17, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 17, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 17, image 3 de 3
    • Separate a cable ribbon from the top right of the motherboard by gently inserting the pry tool under the rectangular metallic piece and lifting.
  18. Xiaomi Mi 3 Side control buttons Replacement: étape 18, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 18, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 18, image 3 de 3
    • Separate a cable ribbon from the top right of the motherboard - near the cable from the previous step - by gently inserting the pry tool under the rectangular metallic piece and lifting.
  19. Xiaomi Mi 3 Side control buttons Replacement: étape 19, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 19, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 19, image 3 de 3
    • Using a pry tool, gently lift the side control buttons assembly away from the case. They should be loosely connected to the motherboard.
  20. Xiaomi Mi 3 Side control buttons Replacement: étape 20, image 1 de 2 Xiaomi Mi 3 Side control buttons Replacement: étape 20, image 2 de 2
    • Remove these two screws.
  21. Xiaomi Mi 3 Side control buttons Replacement: étape 21, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 21, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement: étape 21, image 3 de 3
    • Remove the motherboard from the panel carefully. Use the pry tool as a lever from the top of the panel and lift if from that side.
  22. Xiaomi Mi 3 Side control buttons Replacement: étape 22, image 1 de 1
    • The motherboard has now been successfully removed.
  23. Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: étape 23, image 1 de 3 Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: étape 23, image 2 de 3 Xiaomi Mi 3 Side control buttons Replacement, Side control buttons: étape 23, image 3 de 3
    • With the motherboard removed flip it over onto its front and use a small pry tool to gently disconnect the side buttons from the back of the motherboard.
Tyler Howard
Membre depuis le 09/02/15
705 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-5, Remmell Fall 2015
USFT-REMMELL-F15S1G5
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 2,561
