Introduction
Use this guide to replace a worn-out or dead battery in your Xiaomi Mi 8.
If your battery is swollen, take appropriate precautions. For your safety, discharge your battery below 25% before disassembling your phone. This reduces the risk of a dangerous thermal event if the battery is accidentally damaged during the repair.
You’ll need replacement adhesive to reattach components when reassembling the device.
Ce dont vous avez besoin
Apply a heated iOpener to the rear glass to loosen the adhesive beneath the edges. Apply the iOpener for at least two minutes.
Secure a suction handle to the lower edge of the rear glass, as close to the edge as possible.
Lift the rear glass with the suction handle to create a gap between the glass and the frame.
Insert an opening pick into the gap.
Slide the opening pick to the bottom right corner of the phone.
Insert a third opening pick at the bottom left corner.
Start to slide the opening pick from the bottom left corner along the side of the Xiaomi Mi 8 to cut the adhesive.
As the adhesive cools down it gets harder to cut. If necessary use your iOpener to reheat it.
Leave the opening pick in the top left corner to prevent the adhesive from resealing.
Remove the ten screws that secure the motherboard cover.
Eight Phillips #00 screws (3.4 mm length)
Two Phillips #00 screws (3.5 mm length)
Use a spudger to pry up and disconnect the battery flex cable located at the bottom of the motherboard.
Use a pair of tweezers to peel the black ends of the adhesive tabs off the battery.
If possible, turn on your phone and test your repair before installing new adhesive and resealing the phone.
Secure the new battery with pre-cut adhesive or double-sided adhesive tape. In order to position it correctly, apply the new adhesive into the phone at the places where the old adhesive was located, not directly onto the battery. Press the new battery firmly into place.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%
22 autres ont terminé cette réparation.
11 commentaires
Thanks ! Its helps me alot
Echt Klasse, allerdings sind es 8 schwarze schrauben bei der Mainboard Abdeckung. Ansonsten echt top Anleitung, vielen Dank
Die deutsche Übersetzung war veraltet, ich habe sie aktualisiert. Danke! Viel Spaß mit deinem Xiaomi.
