Aller au contenu principal
Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement
Ce dont vous avez besoin
  1. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement, Battery: étape 1, image 1 de 2 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement, Battery: étape 1, image 2 de 2
    • Use your suction cup to grip the back of the phone. Once the suction cup is secure, pull back with moderate force and the back plate should snap free.
  2. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 2, image 1 de 3 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 2, image 2 de 3 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 2, image 3 de 3
    • Once the back plate is off you will need to detach the frames that hold in the battery. Locate and remove the screws (Screws are marked in the image). You can then pull the frame off with ease once the screws have been removed.
    • Remove the six 3.5mm Phillips #000 black screws using a securing part of the back panels.
    • Remove the seven 2.5mm Phillips #000 black screws securing part of the back panels.
    • Remove the five 2mm Phillips #000 silver screws securing the remaining back panels.
  3. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 3, image 1 de 1
    • Use a nylon spudger to pry upwards to detach the ribbon that's connecting the battery to the motherboard.
  4. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 4, image 1 de 2 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 4, image 2 de 2
    • Insert a nylon or metal spudger underneath the battery at any point. Then slide the spudger around all the edges to loosen it. The battery can now be easily lifted out of the frame.
    • Glue will be holding down the backside of the battery.
  5. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement, Micro USB/Microphone/Virtual Keys light/Vibrator: étape 5, image 1 de 2 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement, Micro USB/Microphone/Virtual Keys light/Vibrator: étape 5, image 2 de 2
    • Use tweezers to pull upwards and detach the microphone wire that connects the motherboard to the dock connector.
  6. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 6, image 1 de 1
    • Peel back the ribbon that is adhered to the metal surface as shown.
  7. Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 7, image 1 de 3 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 7, image 2 de 3 Xiaomi Mi Note Micro USB/Microphone/Virtual Keys light/Vibrator Replacement: étape 7, image 3 de 3
    • The dock connector is firmly adhered to the frame below it. To prevent damage to the phone use minimal force when removing.
    • Using tweezers slowly start prying upwards at the locations shown in the images. After carefully prying around the edges of the dock connector, it can now lifted upwards out of the frame.
9 autres ont terminé cette réparation.
Mark Sears
Membre depuis le 08/27/15
1 231 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team 1-6, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 1-6, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G6
4 membres
6 tutoriels rédigés
Un commentaire
Très difficile de retirer le pcb avec le prise mini USB et impossible de des souder directement bien sur. Le buzzer est justement mal placé et gène horriblement. Environ 1h pose/dépose.
Christophe C - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 21
Total : 4,607
