Aller au contenu principal
Xiaomi Redmi 2 Front Speaker Replacement
Ce dont vous avez besoin
  1. Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: étape 1, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement, Motherboard: étape 1, image 2 de 2
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Xiaomi Redmi 2 Front Speaker Replacement: étape 2, image 1 de 1
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Xiaomi Redmi 2 Front Speaker Replacement: étape 3, image 1 de 1
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Xiaomi Redmi 2 Front Speaker Replacement: étape 4, image 1 de 1
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Xiaomi Redmi 2 Front Speaker Replacement: étape 5, image 1 de 1
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Xiaomi Redmi 2 Front Speaker Replacement: étape 6, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Xiaomi Redmi 2 Front Speaker Replacement: étape 7, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement: étape 7, image 2 de 2
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Xiaomi Redmi 2 Front Speaker Replacement: étape 8, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement: étape 8, image 2 de 2
    • Lift and hinge the motherboard with your fingers.
  9. Xiaomi Redmi 2 Front Speaker Replacement: étape 9, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement: étape 9, image 2 de 2
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Xiaomi Redmi 2 Front Speaker Replacement: étape 10, image 1 de 2 Xiaomi Redmi 2 Front Speaker Replacement: étape 10, image 2 de 2
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Xiaomi Redmi 2 Front Speaker Replacement: étape 11, image 1 de 1
    • Lift the motherboard out of the front cover and set aside.
  12. Xiaomi Redmi 2 Front Speaker Replacement, Front Speaker: étape 12, image 1 de 1
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Xiaomi Redmi 2 Front Speaker Replacement: étape 13, image 1 de 1
    • Using your fingers, gently lift the front speaker from the screen assembly.
7 autres ont terminé cette réparation.
Alicia Brenner
Membre depuis le 10/01/15
3 539 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 membres
5 tutoriels rédigés
4 commentaires
How can I remove the contact from the speaker? I bought a new screen and it hasn't this contact and the vibracall module, but the second I know how to remove from the old screen.
brunofichos - Réponse
sorry about my english, I want to say "back speaker's contact" not "contact from the speaker". Thanks
brunofichos -
You know how to remove the speaker contacts from the rear speaker. It's stuck in the redmi2pro frame. I bought an LCD touch frame and need to move the components to the new one.
afreitasleonardo - Réponse
Rademi 2 front Speakers problem
Amol Surve - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 15
Total : 7,098
