Aller au contenu principal
Introduction
Use this guide to remove the screen assembly of your Xiaomi Redmi 2 for repair or replacement of any parts attached.
Pièces
Aucune pièce spécifiée.
  1. Use the flat end of the spudger to remove the back panel from the mid-frame and front body. Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
    • Use the flat end of the spudger to remove the back panel from the mid-frame and front body.
  2. Insert your finger into the curved opening of the mid-frame.
    • Insert your finger into the curved opening of the mid-frame.
    • Lift the battery and remove.
  3. Remove the SIM and/or memory cards if present.
    • Remove the SIM and/or memory cards if present.
    • Remove twelve 3.4 mm Phillips #000 screws securing the mid-frame to the front body.
  4. Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
    • Slide the spudger between the mid-frame and front body, gradually prying the two bodies apart as you slide the spudger around the perimeter of the phone.
  5. Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Remove the 3.4 mm Phillips #000 screw that holds the motherboard to the front body.
    • Keep this screw separate from the initial twelve.
  6. Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector. Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
    • Using one prong of the tweezers, pry back the brown clip located on top of the LCD ribbon connector.
  7. Using one prong of the tweezers, pry the ribbon clip away from the motherboard. Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
    • Using one prong of the tweezers, pry the ribbon clip away from the motherboard.
  8. Lift and  hinge the motherboard with your fingers. Lift and  hinge the motherboard with your fingers.
    • Lift and hinge the motherboard with your fingers.
  9. Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector. Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
    • Using one prong of the tweezers, lift and pry back the metal clip positioned over the front proximity sensor ribbon connector.
  10. Using the tweezers, pull the antenna connector from the motherboard. Using the tweezers, pull the antenna connector from the motherboard.
    • Using the tweezers, pull the antenna connector from the motherboard.
  11. Lift the motherboard out of the front cover and set aside.
    • Lift the motherboard out of the front cover and set aside.
  12. Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
    • Using the nylon or metal spudger, gently pry the front speaker from the screen assembly.
  13. Using your fingers, gently lift the front speaker from the screen assembly.
    • Using your fingers, gently lift the front speaker from the screen assembly.
  14. Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
    • Remove the 2.9 mm Phillips #000 screw that holds the PCB circuit board to the screen assembly.
  15. Using the tweezers, lift the antenna connector from the PCB circuit board.
    • Using the tweezers, lift the antenna connector from the PCB circuit board.
  16. Do not remove the PCB circuit board at this time. Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
    • Do not remove the PCB circuit board at this time.
    • Using the nylon or metal spudger, gently pry back the top of the PCB circuit board from the screen assembly.
  17. Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
    • Using the nylon or metal spudger, pry back the silver clip covering the ribbon connector.
  18. Carefully lift the PCB circuit board from the screen assembly and set aside. The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
    • Carefully lift the PCB circuit board from the screen assembly and set aside.
    • The screen assembly is pictured to the left of the circuit board and is now ready for repair or replacement.
31 autres ont terminé cette réparation.
Alicia Brenner
Membre depuis le 01/10/2015
3 509 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-3, Leahy Fall 2015 Membre de l'équipe USF Tampa, Team 1-3, Leahy Fall 2015
USFT-LEAHY-F15S1G3
2 membres
5 tutoriels rédigés
2 commentaires
ok so good is can service nice
SAFUTRA - Réponse
Touch is not working after replacing full LCD, Brought new display & changed again but no luck, Display is okay but touch not working.
Rajesh Gopisetti - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 27
Total : 16,914
