Aller au contenu principal
Xiaomi Redmi Note 3 Disassembly Guide
Ce dont vous avez besoin
  1. Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: étape 1, image 1 de 2 Xiaomi Redmi Note 3 Disassembly Guide, Eject the Sim Card Tray: étape 1, image 2 de 2
    • Locate the sim card tray at the right side of the phone
    • Insert the metal needle sim tool into the tray hole to eject the tray and pull it out
  2. Xiaomi Redmi Note 3 Disassembly Guide, Remove Phone Panel: étape 2, image 1 de 1
    • Insert your thumb in between the back panel and the front of phone and slowly follow along the edges to separate the two pieces
  3. Xiaomi Redmi Note 3 Disassembly Guide, Disconnect the Connector: étape 3, image 1 de 1
    • Remove the plastic connector that links the battery with the motherboard by gently prying the ends of the connector from each side of the phone
  4. Xiaomi Redmi Note 3 Disassembly Guide, Begin Battery Removal: étape 4, image 1 de 1
    • Pull the black tab at the top left of the battery to disconnect the battery from the system
  5. Xiaomi Redmi Note 3 Disassembly Guide, Remove Battery: étape 5, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Wedge the tweezers under the battery to lift it up
    • Remove as much as adhesive as needed to lift the battery from phone using tweezers or fingers
    • Adhesive that binds the battery to the phone can be strong and this may require a little bit of effort to remove the battery
  6. Xiaomi Redmi Note 3 Disassembly Guide, Unscrew Speaker: étape 6, image 1 de 1
    • Use the screwdriver to unscrew the speaker at the bottom back of the phone. There are five screws around the edges of the speaker
  7. Xiaomi Redmi Note 3 Disassembly Guide, Detach Speaker: étape 7, image 1 de 1
    • Remove the loud speaker cover using the tweezers to expose the daughterboard
  8. Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: étape 8, image 1 de 2 Xiaomi Redmi Note 3 Disassembly Guide, Remove Daughterboard: étape 8, image 2 de 2
    • Remove the two gold tabs on the two top corners of the daughterboard
    • Pry the daughterboard open with the tweezers or pull it out using your fingers
    • There is a heat shield underneath the daughter board and it can get hot from charging the phone so make sure you don’t touch it
  9. Xiaomi Redmi Note 3 Disassembly Guide, Begin to Remove Camera: étape 9, image 1 de 1
    • Unscrew the four screws at the top of the motherboard and pop up the top cover
    • One screw might by disguised by a sticker so locate that and remove the sticker as well
    • Pulling the top cover without removing all the screws might damage the motherboard
  10. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera Cushion: étape 10, image 1 de 1
    • Remove the rubber cover that’s containing the camera
  11. Xiaomi Redmi Note 3 Disassembly Guide, Remove Front Camera Protector: étape 11, image 1 de 1
    • Pull the tab that’s holding the front camera to remove the camera protector
    • To keep the camera from damage hold the camera from the corner and not from the middle of it
  12. Xiaomi Redmi Note 3 Disassembly Guide, Remove Camera: étape 12, image 1 de 1
    • Pull out the front camera using tweezers or your fingers
  13. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard Connectors: étape 13, image 1 de 1
    • Remove the five connectors of the motherboard using tweezers or your fingers
  14. Xiaomi Redmi Note 3 Disassembly Guide, Remove Motherboard: étape 14, image 1 de 1
    • Remove the remaining four screws as your work down to the bottom to loosen the motherboard
  15. Xiaomi Redmi Note 3 Disassembly Guide, Admire Disassembled Phone: étape 15, image 1 de 1
    • Congrats -- You disassembled the Xiaomi Redmi Note 3!
Meaghan Owens
Membre depuis le 06/23/23
241 Réputation
1 tutoriel rédigé
Équipe
Group 2 Eng Communications Membre de l'équipe Group 2 Eng Communications
Community
4 membres
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 16
30 derniers jours : 72
Total : 568
