Aller au contenu principal
Xiaomi Redmi Note Motherboard Replacement
Ce dont vous avez besoin
  1. Xiaomi Redmi Note Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Make sure the Xiaomi Redmi Note is powered off before removing the battery.
    • Insert the plastic opening tool between the charging port and the rear case.
    • Pry the end of the rear case up from the charging port.
  2. Xiaomi Redmi Note Motherboard Replacement: étape 2, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement: étape 2, image 2 de 2
    • Run the plastic opening tool along the seam on the side of the phone to remove the rear casing.
  3. Xiaomi Redmi Note Motherboard Replacement: étape 3, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement: étape 3, image 2 de 2
    • Locate the indentation at the bottom of the battery.
    • Place a finger in the indentation and lift up to remove the battery.
  4. Xiaomi Redmi Note Motherboard Replacement, Midframe: étape 4, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement, Midframe: étape 4, image 2 de 2
    • Remove twelve 3.5mm Phillips #00 screws from the midframe.
  5. Xiaomi Redmi Note Motherboard Replacement: étape 5, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement: étape 5, image 2 de 2
    • Insert a plastic opening into the seam between the midframe and the bottom frame of the phone.
    • Run the plastic opening tool along the seam.
    • Pry up the midframe with the plastic opening tool.
    • Once the midframe has been sufficiently lifted with the tool, place a hand underneath the edge to lift the entire component out of the frame.
    • There will be snapping sounds as the clips on the midframe disconnect from the phone.
  6. Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: étape 6, image 1 de 3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: étape 6, image 2 de 3 Xiaomi Redmi Note Motherboard Replacement, Front-Facing Camera: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    • Use tweezers to lift the retaining flap of the zero insertion force (ZIF) connector to the upright position.
    • Use tweezers to pull the ribbon cable out of the ZIF connector.
    • Remove the front-facing camera from the motherboard.
  7. Xiaomi Redmi Note Motherboard Replacement, Rear Camera: étape 7, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement, Rear Camera: étape 7, image 2 de 2
    • Disconnect the rear-facing camera from the motherboard by pulling out the press-fit connector to its left.
  8. Xiaomi Redmi Note Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Locate the three ZIF connectors on the motherboard.
  9. Xiaomi Redmi Note Motherboard Replacement: étape 9, image 1 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 9, image 2 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 9, image 3 de 3
    • Use tweezers to lift the retaining flap on the ZIF connector to the upright position.
    • Pull the ribbon cable out of the connector by pulling to the left.
    • Repeat these steps for the other two ZIF connectors.
  10. Xiaomi Redmi Note Motherboard Replacement: étape 10, image 1 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 10, image 2 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 10, image 3 de 3
    • Locate the antenna cable on the bottom right of the motherboard and use tweezers to lift the cable off of the motherboard.
  11. Xiaomi Redmi Note Motherboard Replacement: étape 11, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement: étape 11, image 2 de 2
    • Remove the two 2.9mm Philips #00 screws.
  12. Xiaomi Redmi Note Motherboard Replacement: étape 12, image 1 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 12, image 2 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 12, image 3 de 3
    • Flip over the motherboard to reveal the back.
    • Use a plastic opening tool to pry off the snap fit connector, located on the bottom right off of the motherboard.
  13. Xiaomi Redmi Note Motherboard Replacement: étape 13, image 1 de 2 Xiaomi Redmi Note Motherboard Replacement: étape 13, image 2 de 2
    • Lift up the motherboard and turn it over to place it by the side of the phone.
    • Do not attempt to remove the motherboard at this stage. Pulling on the board can damage its connection to the vibrating motor.
  14. Xiaomi Redmi Note Motherboard Replacement: étape 14, image 1 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 14, image 2 de 3 Xiaomi Redmi Note Motherboard Replacement: étape 14, image 3 de 3
    • Use tweezers to peel the vibrating motor off the frame of the phone.
    • The vibrating motor is glued to the frame, so do not be afraid to use force to dislodge it.
15 autres ont terminé cette réparation.
AJ Beers
Membre depuis le 04/26/17
213 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S22-G4, Livingston Spring 2017 Membre de l'équipe Cal Poly, Team S22-G4, Livingston Spring 2017
CPSU-LIVINGSTON-S17S22G4
4 membres
16 tutoriels rédigés
5 commentaires de tutoriel
Good explanation, but the question is : Where to get Xiaomi replacement motherboards ?
Adriano Fonseca - Réponse
can we shift bords memory to other bord
krishna - Réponse
No we can't get motherboard's memory if it is damaged
sai teja -
Besten Dank an alle für Die Mühe, die sie sich jeweils geben um verständliche Anleitungen zu erstellen,
Oigres Ailgevar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 27
30 derniers jours : 85
Total : 25,874
