Aller au contenu principal
Pour réparer ensemble - Je crée un compte
YORK TM9Y080B12MP11 Furnace Filter Replacement
Ce dont vous avez besoin
    1. YORK TM9Y080B12MP11 Furnace Filter Replacement, Filter: étape 1, image 1 de 1
      • Turn off the furnace by either using the switch near to the furnace or by turning the temperature down with the thermostat.
      Demander à FixBot
      Ajouter un commentaire
    2. YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 2, image 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 2, image 2 de 2
      • Pull the handhold with force in order to open the 'door' to the filter's location.
      • You will hear a 'pop' and the door should come off easily.
      Demander à FixBot
    3. YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 3, image 1 de 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 3, image 2 de 3 YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 3, image 3 de 3
      • Remove the old filter completely by pulling the filter out of its location.
      • On the top of the filter there is an arrow pointing in a specific direction. Make sure you remember that direction.
      Demander à FixBot
    4. YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 4, image 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 4, image 2 de 2
      • Insert the new filter by sliding it into the same place where the old filter was.
      • Make sure that the arrow on the top of the filter is pointing in the same direction as the old filter was.
      • Make sure that the filter is as far back as it can go.
      Demander à FixBot
    5. YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 5, image 1 de 2 YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 5, image 2 de 2
      • Reattach the door by lining it up with the inside edges of the opening.
      • Use force to make sure that the door is fully secure into its position so that the door does not fall off. You should hear a sound similar to a click once the door is correctly in place.
      Demander à FixBot
    6. YORK TM9Y080B12MP11 Furnace Filter Replacement: étape 6, image 1 de 1
      • Turn back on the furnace.
      • You can do this by flipping the switch back on or by turning the furnace on with the thermostat.
      Demander à FixBot
Ligne d'arrivée
DevBos
Membre depuis le 01/09/24
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team 1-8, O'Regan Winter 2024 Membre de l'équipe York University, Team 1-8, O'Regan Winter 2024
YORK-O'REGAN-W24S1G8
1 membre
12 tutoriels rédigés
1 commentaire de tutoriel
very good explanation
5 Stars hvac services - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 18
30 derniers jours : 85
Total : 2,572
