Aller au contenu principal
Yamaha Alto Saxophone Neck-piece Cork Replacement
Ce dont vous avez besoin
  1. Yamaha Alto Saxophone Neck-piece Cork Replacement, YAS-23 Yamaha Alto Saxophone Neck-piece Cork: étape 1, image 1 de 2 Yamaha Alto Saxophone Neck-piece Cork Replacement, YAS-23 Yamaha Alto Saxophone Neck-piece Cork: étape 1, image 2 de 2
    • The octave key is silver, while the rest of the neck-piece is gold.
    • Locate the screw on the side of the neck-piece, connecting the octave key to the neck-piece.
    • Use a small, 2.5 mm flat head screwdriver to remove the screw.
  2. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 2, image 1 de 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 2, image 2 de 2
    • Open a paperclip.
    • Push the screw out with the end of the paperclip.
  3. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 3, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 3, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 3, image 3 de 3
    • Slide the octave key down off the bottom of the neck-piece.
  4. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 4, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 4, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 4, image 3 de 3
    • Put on leather gloves.
    • Cut away from one's self.
    • Use the utility blade to scrape off the cork.
    • Start at the base of the cork on the neck-piece with the utility blade at a 10 to 20 degree angle.
    • In a controlled motion, drag the utility blade along the neck-piece, removing cork along the way.
    • Repeat until all of the cork is removed.
  5. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 5, image 1 de 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 5, image 2 de 2
    • Apply masking tape where there is no glue on the neck-piece to prevent damage to the finish.
  6. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 6, image 1 de 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 6, image 2 de 2
    • Remove glue and resin by rotating the neck-piece against the 220 grit sand paper.
    • Repeat until all glue is gone.
  7. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 7, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 7, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 7, image 3 de 3
    Outil utilisé dans cette étape :
    Microfiber Cleaning Cloths
    $3.99
    J'achète
    • New cork may not adhere correctly without completing this step.
    • With a damp microfiber cleaning cloth, wipe off any dust and glue particles.
  8. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 8, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 8, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 8, image 3 de 3
    • Do not remove adhesive covering on the Valentino neck cork.
    • Make sure the shorter base of the Valentino neck cork is flush with entrance.
    • Place the Valentino neck cork flush with the entrance of the neck-piece.
    • Mark a line where the Valentino neck cork meets the masking tape.
    • Cut along the line.
  9. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 9, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 9, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 9, image 3 de 3
    • Wrap Valentino neck cork around the neck-piece.
    • Make mark where the Valentino neck cork overlaps.
    • Make sure the shorter base of Valentino neck cork is flush with entrance to neck-piece.
    • If Valentino neck cork appears to be too small on one side, rotate 180 degrees.
  10. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 10, image 1 de 1
    • Cut the Valentino neck cork along the line made in the previous step.
  11. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 11, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 11, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 11, image 3 de 3
    • Remove the adhesive covering on the back of the Valentino neck cork.
    • Wrap the Valentino neck cork around the top of neck-piece.
    • Place the narrow end of the Valentino neck cork flush with the tip of the neck-piece.
  12. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 12, image 1 de 1
    • Remove the masking tape.
  13. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 13, image 1 de 2 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 13, image 2 de 2
    • Sand the seam of the Valentino neck cork until it is even with the rest of the Valentino neck cork.
  14. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 14, image 1 de 1
    • Apply a generous amount of cork grease on the whole Valentino neck cork.
  15. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 15, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 15, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 15, image 3 de 3
    • Place the octave key on the neck-piece.
  16. Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 16, image 1 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 16, image 2 de 3 Yamaha Alto Saxophone Neck-piece Cork Replacement: étape 16, image 3 de 3
    • Re-insert the screw.
    • Tighten the screw with a small, 2.5 mm flat head screwdriver.
    • The replacement is complete.
    • When applying a mouthpiece to the neck-piece for the first time, it will be difficult and require force. This is normal.
Ligne d'arrivée
Lauren Wintermute
Membre depuis le 01/16/20
277 Réputation
1 tutoriel rédigé
Un commentaire
I’m usually here for computer guides, I couldn’t believe a sax guide was here! Was overjoyed! Can someone make a Alto Sax full pad replacement guide? I know it’s a big ask! But I have a YAS-23 and it needs all new pads, getting it serviced by a pro is between $700-$850!! But buying pads yourself is as low as $50 or on the high end $200. This seems like a tutorial the world needs to have! Thank you to anyone that even took the time to read this.
Cameron - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 27
Total : 1,775
