Aller au contenu principal
Yamaha YPG-225 Keys Replacement
Ce dont vous avez besoin
  1. Yamaha YPG-225 Keys Replacement, Batteries: étape 1, image 1 de 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Keys Replacement: étape 2, image 1 de 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Keys Replacement: étape 3, image 1 de 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Keys Replacement, Faceplate: étape 4, image 1 de 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Keys Replacement: étape 5, image 1 de 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Keys Replacement: étape 6, image 1 de 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Keys Replacement: étape 7, image 1 de 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Keys Replacement: étape 8, image 1 de 2 Yamaha YPG-225 Keys Replacement: étape 8, image 2 de 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Keys Replacement, Keys: étape 9, image 1 de 1
    • Remove the 32mm screws that hold keys down.
    • Depending on which block of keys you wish to remove, there may be four screws instead of three.
  10. Yamaha YPG-225 Keys Replacement: étape 10, image 1 de 1
    • Remove the block of keys that holds the key you wish to install.
    • To do this, apply a small force away from the top of the keys and slightly toward the floor.
    • If done correctly, the block of keys will come to a slight downward angle.
  11. Yamaha YPG-225 Keys Replacement: étape 11, image 1 de 2 Yamaha YPG-225 Keys Replacement: étape 11, image 2 de 2
    • Press the tab on the back side of the block of keys out and detach the black keys.
  12. Yamaha YPG-225 Keys Replacement: étape 12, image 1 de 1
    • Remove the individual white key(s) or the black key set(s) that require replacement.
7 autres ont terminé cette réparation.
Kevin Green
Membre depuis le 09/18/12
308 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 2-62, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 membres
6 tutoriels rédigés
3 commentaires
Excellent, Although I've got a different type of yamaha keyboard, still good inside info.
Diederick Fokker - Réponse
Great article. Thank you so much.
Andreas Devig - Réponse
The instructions were very good and easy to understand. Question on the same subject. How about keys that have popped up on the key bed.
Donald Bryant - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 14
30 derniers jours : 33
Total : 21,216
