Aller au contenu principal
Yamaha YPG-225 Speaker Replacement
Ce dont vous avez besoin
  1. Yamaha YPG-225 Speaker Replacement, Batteries: étape 1, image 1 de 1
    • Turn the keyboard over so that the keys are facing the ground.
  2. Yamaha YPG-225 Speaker Replacement: étape 2, image 1 de 1
    • Pop the tabs on the battery casing and remove it from the back plate.
  3. Yamaha YPG-225 Speaker Replacement: étape 3, image 1 de 1
    • Locate the six batteries and remove them from the battery cavity.
  4. Yamaha YPG-225 Speaker Replacement, Faceplate: étape 4, image 1 de 1
    • Remove the six 10mm screws at the top of the backplate.
  5. Yamaha YPG-225 Speaker Replacement: étape 5, image 1 de 1
    • Remove the seven 12mm screws in the middle of the back plate.
  6. Yamaha YPG-225 Speaker Replacement: étape 6, image 1 de 1
    • Remove the eight 10mm screws from the side and the bottom of the back plate.
  7. Yamaha YPG-225 Speaker Replacement: étape 7, image 1 de 1
    • As the face plate is no longer connected to the body of the keyboard, be careful to not drop the body when performing this step.
    • Flip over the keyboard.
  8. Yamaha YPG-225 Speaker Replacement: étape 8, image 1 de 2 Yamaha YPG-225 Speaker Replacement: étape 8, image 2 de 2
    • Lifting from the front and the back of the face plate equally, pull the face plate up and then back, away from the keyboard.
    • Be careful when removing the face plate. There are wires attached.
  9. Yamaha YPG-225 Speaker Replacement, Speaker: étape 9, image 1 de 1
    • Locate the speaker and remove the four 10mm screws in the corners of the speaker.
  10. Yamaha YPG-225 Speaker Replacement: étape 10, image 1 de 1
    • Unplug the speaker's black and red wires from the small circuit board.
    • Do not be afraid to use a little force to get the plug out, but take care not to pull the wires from the plug.
  11. Yamaha YPG-225 Speaker Replacement: étape 11, image 1 de 1
    • Remove the translucent blue tape that holds the speaker wires to the keyboard.
3 autres ont terminé cette réparation.
Lonnie Bissmeyer
Membre depuis le 09/16/12
444 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 2-62, Propen Fall 2012 Membre de l'équipe Cal Poly, Team 2-62, Propen Fall 2012
CPSU-PROPEN-F12S2G62
2 membres
6 tutoriels rédigés
3 commentaires
I need to replace a speaker on a Yamaha YPG-625 88 note digital piano .....is this the same thing I should do like the piano you are showing on this web sight ? Also the big screen in the middle of the piano that says what tone you select and the drum patterns is sorta kinda going out ! could it be just getting dirty and need contact cleaning ? The place that sells these Yamaha pianos said they would have to send it away to have the repairs done and the cost would be OVER $500.00 ! Any help would be greatly helpful ! Mark Rockwell Galena , Il flyingfingersmark1@yahoo.com 815-777-4928
flyingfingersmark1 - Réponse
I replaced my DGX 640’s bad speakers with PHILIPS 5.5 inch, 3 way car speakers. I never liked the DGX’s sound. They are dull and too mellow. Oh. man! Now, after replacing the onboard speakers, they sound crisp. I realized that Yamaha is not my parents. They need to earn profit, pay salaries. So, obviously, like all consumer products,m they are not well built. The speakers in those keyboards are not exceptions. They are cheaply made.
ralakshitaran - Réponse
I need to replace the speaker of my Yamaha psr535 what is the size of the speaker to prepare before dismantling the keyboard? and what is the best speaker to replace it?
Thank you in advance
pedrolacanilao75 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 20
Total : 8,904
