Aller au contenu principal
Yuneec Breeze 4K Motherboard Replacement
Ce dont vous avez besoin
  1. Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: étape 1, image 1 de 2 Yuneec Breeze 4K Motherboard Replacement, Motherboard M7: étape 1, image 2 de 2
    • Before you begin start by putting on a ESD wrist strap to prevent ESD damage and remove the battery.
    • Flip over the drone so that the propellers are facing down and the camera is facing up.
  2. Yuneec Breeze 4K Motherboard Replacement: étape 2, image 1 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 2, image 2 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 2, image 3 de 3
    • Grip the cover that covers the rest of the wires, and give it a slight pull to remove it.
  3. Yuneec Breeze 4K Motherboard Replacement: étape 3, image 1 de 1
    • Remove the 4 rubber plugs that hold the drone and its internal parts together.
    • These plugs can be located in each corner of the drone, and are white.
  4. Yuneec Breeze 4K Motherboard Replacement: étape 4, image 1 de 1
    • Unplug the four cables that are connected on the top face of the frame.
  5. Yuneec Breeze 4K Motherboard Replacement: étape 5, image 1 de 2 Yuneec Breeze 4K Motherboard Replacement: étape 5, image 2 de 2
    • The rest of the wires that are still connected can be unplugged.
    • Using a pair of tweezers they can be unplugged.
  6. Yuneec Breeze 4K Motherboard Replacement: étape 6, image 1 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 6, image 2 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 6, image 3 de 3
    • Lift up or tilt entire frame and mother board and unplug all the wires.
  7. Yuneec Breeze 4K Motherboard Replacement: étape 7, image 1 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 7, image 2 de 3 Yuneec Breeze 4K Motherboard Replacement: étape 7, image 3 de 3
    • The battery connector has two wires connected to a plug in with two little screws.
    • Unscrew the two screws and pull it apart using a small tweezers.
  8. Yuneec Breeze 4K Motherboard Replacement: étape 8, image 1 de 1
    • Flip over the frame and mother board and unscrew the mother board.
    • There are four screws on each corner of the mother board.
  9. Yuneec Breeze 4K Motherboard Replacement: étape 9, image 1 de 2 Yuneec Breeze 4K Motherboard Replacement: étape 9, image 2 de 2
    • After the screws are out, the motherboard can be pulled out softly with hands.
    • Remove the motherboard from the device.
5 autres ont terminé cette réparation.
Ryanne Millis
Membre depuis le 10/04/18
318 Réputation
1 tutoriel rédigé
Équipe
UW Stout, Team S6-G5, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G5, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G5
4 membres
4 tutoriels rédigés
Un commentaire
Excellent step by step instructions.
paul_courville - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 11
Total : 1,940
