Aller au contenu principal
Yuneec Typhoon H Gimbal Bushing Reattachment
Ce dont vous avez besoin
  1. Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: étape 1, image 1 de 2 Yuneec Typhoon H Gimbal Bushing Reattachment, Gimbal Bushing Connectors to Camera Mount: étape 1, image 2 de 2
    • In order to repair the camera and camera gimbal, remove the camera configuration from the body of the drone.
    • Pull up on the tab connected to the camera configuration and slide the entire apparatus off.
  2. Yuneec Typhoon H Gimbal Bushing Reattachment: étape 2, image 1 de 3 Yuneec Typhoon H Gimbal Bushing Reattachment: étape 2, image 2 de 3 Yuneec Typhoon H Gimbal Bushing Reattachment: étape 2, image 3 de 3
    • Put the gimbal bushings (the rubber balls) back into the plastic alignment mounts.
    • The circle that is separated from the main body of the bushing should then be inserted into the hole.
    • When pushing these bushings back into place, it is smart to use a skinny tool or toothpick.
To reassemble your device, simply slide the camera mount back onto the bottom of the drone.
2 autres ont terminé cette réparation.
Jake Breul
Membre depuis le 04/16/18
127 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S22-G3, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 membres
5 tutoriels rédigés
3 commentaires
Camera not getting power after crash.
Don - Réponse
Crashed drone and camera not getting power anymore. Nothing appears to be broken.
Don - Réponse
Did steps. Bushings ok. Camera still won't communicate.
vickiesamus - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 19
Total : 1,639
