Aller au contenu principal
Yuneec Typhoon H Landing Gear Replacement
Ce dont vous avez besoin
  1. Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: étape 1, image 1 de 2 Yuneec Typhoon H Landing Gear  Replacement, Landing Gear: étape 1, image 2 de 2
    • Lift all drone arms up so you can access the landing gear easily.
  2. Yuneec Typhoon H Landing Gear  Replacement: étape 2, image 1 de 3 Yuneec Typhoon H Landing Gear  Replacement: étape 2, image 2 de 3 Yuneec Typhoon H Landing Gear  Replacement: étape 2, image 3 de 3
    • Unscrew the 16.9 mm screw at the top of the landing leg with a Phillips #00 screwdriver.
    • Make sure the screw head is not stripped in the process.
    • If stripped, the whole leg, including the internal sensors, will need to be replaced.
  3. Yuneec Typhoon H Landing Gear  Replacement: étape 3, image 1 de 1
    • Pull the landing leg out slowly and remove it from the device.
Your Yuneec Typhoon H should now be ready to fly safely again.
Shasta Banchio
Membre depuis le 04/16/18
130 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S22-G3, Maness Spring 2018 Membre de l'équipe Cal Poly, Team S22-G3, Maness Spring 2018
CPSU-MANESS-S18S22G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 3
30 derniers jours : 6
Total : 986
