Introduction
Before you start this replacement, make sure to purchase a new Slip Ring Yaw Motor. Likewise, there are several small screws and parts in this motor, so, make sure not to lose these parts during repair.
Ce dont vous avez besoin
Using the Phillips #000 screwdriver, remove the two 4.9 mm screws on the side of the plastic cover holding the wires together.
Once these screws are removed, press down on this plastic cover to reveal the wires. Pull the locking tabs that are on the end of this piece to completely remove this plastic cover.
To reassemble your device, follow these instructions in reverse order (This process is in the guide steps for reference).
3 autres ont terminé cette réparation.
2 commentaires
Ive done all the above but digging out the epoxy it took almost all wire with it i couldve solderd to so what to do now its the white wire by the way the camera still stabalises and points straight just cant manually control
The White or Green wire is most likely not making connection
