Aller au contenu principal
ZD-N Plus Wireless Controller Repair D-Pad Replacement
Ce dont vous avez besoin
  1. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 2, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 2, image 2 de 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Battery: étape 3, image 1 de 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 4, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 4, image 2 de 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 5, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 5, image 2 de 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: étape 6, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, Rumble Motor: étape 6, image 2 de 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
  7. ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: étape 7, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, Motherboard: étape 7, image 2 de 2
    • Remove the three 1.2mm JIS #00 screws that hold the motherboard in place.
  8. ZD-N Plus Wireless Controller Repair D-Pad Replacement: étape 8, image 1 de 1
    • Lift the motherboard out of the controller.
  9. ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: étape 9, image 1 de 2 ZD-N Plus Wireless Controller Repair D-Pad Replacement, D-Pad: étape 9, image 2 de 2
    • Simply remove the plastic piece of the directional pad. It is not glued in so it should come out easily.
Devin Matos
Membre depuis le 10/15/19
181 Réputation
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 176
