Aller au contenu principal
ZD-N Plus Wireless Controller Rumble Motor Replacement
Ce dont vous avez besoin
  1. ZD-N Plus Wireless Controller Rumble Motor Replacement, Back Panel: étape 1, image 1 de 1
    • Remove the seven 12mm JIS #00 screws that hold the back panel in place.
  2. ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 2, image 1 de 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 2, image 2 de 2
    • Lift up on the back panel of the ZD-N Plus to remove it from the rest of the controller.
  3. ZD-N Plus Wireless Controller Rumble Motor Replacement, Battery: étape 3, image 1 de 1
    • Use an opening tool to pry the battery from its original position.
    • The battery is glued on, so this may take some effort.
  4. ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 4, image 1 de 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 4, image 2 de 2
    • Use an opening tool to pry the connector away from the two metallic prongs.
    • The parts are built to stay together, so this may take some effort.
    • Be careful to not warp the prongs in the process.
  5. ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 5, image 1 de 2 ZD-N Plus Wireless Controller Rumble Motor Replacement: étape 5, image 2 de 2
    • Remove the battery from the controller.
  6. ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: étape 6, image 1 de 2 ZD-N Plus Wireless Controller Rumble Motor Replacement, Rumble Motor: étape 6, image 2 de 2
    • Remove the electrical connector attaching each rumble motor to the controller.
    • Lift up on the circular section of the rumble to remove it from the controller.
Jessica Newhouse
Membre depuis le 10/17/19
73 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 15
Total : 259
