Introduction
This guide will show you how to replace the camera in case it breaks or no longer works.
Remove the back cover of the phone to expose the phone's mid-frame.
  • Remove the back cover of the phone to expose the phone's mid-frame.
Ajouter un commentaire
Pry the battery up and out of the phone.
  • Pry the battery up and out of the phone.
Still Not Helping
Eboni - Réponse
  • Lift the battery out of the phone.
  • Use the Phillips Head 00 screw driver to unscrew the seven 0.1mm screws along the perimeter of the phone's mid frame.
  • Wedge the flat end of the spudger between the mid frame and the digitizer.
  • Gently pry the mid frame away from the rest of the phone to expose the motherboard.
  • Use the tweezers to grip the back facing camera. Gently pull until the camera is completely removed from the motherboard.
Jennifer DeMeo
Membre depuis le 07/10/2014
960 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team 1-2, Leahy Fall 2014 Membre de l'équipe USF Tampa, Team 1-2, Leahy Fall 2014
USFT-LEAHY-F14S1G2
4 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 535
