Aller au contenu principal
Introduction
Follow this guide to replace the Battery for the ZTE Blade Spark. To get to this step please see ZTE Blade Spark Disassembly Guide
Pièces
Aucune pièce spécifiée.
  1. Remove the battery: Disconnect the battery's power connector from the device mainframe.
    • Remove the battery:
    • Disconnect the battery's power connector from the device mainframe.
    • Lift the battery from its slot and set aside.
  2. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  3. Install replacement battery:
    • Install replacement battery:
    • Attach the replacement battery by connecting its corresponding power connector to the device mainframe.
    • Then, set the replacement battery properly in place as originally found.
To reassemble your device, follow the instructions on the ZTE Blade Spark Disassembly guide in reverse order.
Hung Vu
Membre depuis le 24/01/2018
600 Réputation
5 tutoriels rédigés
Équipe
Gateway, Team S1-G6, Johnson Spring 2018 Membre de l'équipe Gateway, Team S1-G6, Johnson Spring 2018
GCC-JOHNSON-S18S1G6
2 membres
5 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 27
Total : 110
