Aller au contenu principal
ZTE Blade Spark Battery Replacement
Ce dont vous avez besoin
  1. ZTE Blade Spark Battery Replacement, Battery: étape 1, image 1 de 1
    • Apply heat evenly on the back cover using the iOpener to soften the adhesive.
  2. ZTE Blade Spark Battery Replacement: étape 2, image 1 de 2 ZTE Blade Spark Battery Replacement: étape 2, image 2 de 2
    • Carefully remove the back cover using an opening tool.
  3. ZTE Blade Spark Battery Replacement: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to carefully remove all fifteen 3.0 mm screws.
    • Gently remove the SIM card tray.
  4. ZTE Blade Spark Battery Replacement: étape 4, image 1 de 1
    • To remove the inner white panel/cover, use a plastic opening tool to loosen from each side.
  5. ZTE Blade Spark Battery Replacement: étape 5, image 1 de 1
    • Set the inner white panel to the side.
  6. ZTE Blade Spark Battery Replacement: étape 6, image 1 de 1
    • After removing the inner white panel you should see a black panel. Use a Phillips #00 screwdriver to remove the six 4.0 mm screws.
  7. ZTE Blade Spark Battery Replacement: étape 7, image 1 de 1
    • Remove the black panel, revealing the battery.
  8. ZTE Blade Spark Battery Replacement: étape 8, image 1 de 1
    • Disconnect the tab connecting the battery to the circuit.
  9. ZTE Blade Spark Battery Replacement: étape 9, image 1 de 1
    • Remove the battery from the device.
  10. ZTE Blade Spark Battery Replacement: étape 10, image 1 de 1
    • Place battery off to the side and retrieve new battery.
Andrew Bliss
Membre depuis le 03/27/23
181 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-3, Harley Spring 2023 Membre de l'équipe IUPUI, Team 1-3, Harley Spring 2023
IUPUI-HARLEY-S23S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 17
Total : 136
