Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
This guide will describe and show how to replace ZTE Lever lithium ion battery.
  1. Remove the SD card and the Sim card from the device.
    • Remove the SD card and the Sim card from the device.
    • The Sim and SD cards are not shown here as our device did not come with them.
  2. Use an iFixit opening tool to separate the back from the device. Use an iFixit opening tool to separate the back from the device.
    • Use an iFixit opening tool to separate the back from the device.
  3. Remove the two 1.6mm Phillips #0 screws from the battery plug cover. Remove the cover.
    • Remove the two 1.6mm Phillips #0 screws from the battery plug cover.
    • Remove the cover.
  4. Disconnect the battery cable from the motherboard with a plastic opening tool. Disconnect the battery cable from the motherboard with a plastic opening tool.
    • Disconnect the battery cable from the motherboard with a plastic opening tool.
  5. Use your hands, or a plastic opening tool, to pry the battery from the phone.
    • Use your hands, or a plastic opening tool, to pry the battery from the phone.
Michael Gonzalez
Membre depuis le 29/01/2018
466 Réputation
4 tutoriels rédigés
Équipe
USF Tampa, Team S5-G2, Passmore Spring 2018 Membre de l'équipe USF Tampa, Team S5-G2, Passmore Spring 2018
USFT-PASSMORE-S18S5G2
3 membres
6 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 789
