Aller au contenu principal
ZTE Maven 3 Midframe Replacement
Ce dont vous avez besoin
  1. ZTE Maven 3 Midframe Replacement, Back Cover: étape 1, image 1 de 3 ZTE Maven 3 Midframe Replacement, Back Cover: étape 1, image 2 de 3 ZTE Maven 3 Midframe Replacement, Back Cover: étape 1, image 3 de 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Midframe Replacement, Battery: étape 2, image 1 de 3 ZTE Maven 3 Midframe Replacement, Battery: étape 2, image 2 de 3 ZTE Maven 3 Midframe Replacement, Battery: étape 2, image 3 de 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Midframe Replacement, Midframe: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Midframe Replacement: étape 4, image 1 de 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Midframe Replacement: étape 5, image 1 de 2 ZTE Maven 3 Midframe Replacement: étape 5, image 2 de 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
Emma Thiboutot
Membre depuis le 10/30/23
699 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 5
Total : 28
