Introduction
The midframe of a phone might require replacement due to damage from impacts, bends, or cracks that compromise its structural integrity. A damaged midframe can affect the device's overall stability, potentially loosening internal components or hindering proper assembly.
Swapping the midframe restores the phone's structural integrity, allowing for secure housing of internal components and ensuring a snug fit for other parts during reassembly.
Ce dont vous avez besoin
Locate the small indent on the back right bottom corner of the phone.
Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
Locate the battery in the middle of the back of the phone.
Push in and up on the battery to remove it from its slot.
Put the battery aside.
Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
