Aller au contenu principal
ZTE Maven 3 Motherboard Replacement
Ce dont vous avez besoin
  1. ZTE Maven 3 Motherboard Replacement, Back Cover: étape 1, image 1 de 3 ZTE Maven 3 Motherboard Replacement, Back Cover: étape 1, image 2 de 3 ZTE Maven 3 Motherboard Replacement, Back Cover: étape 1, image 3 de 3
    • Locate the small indent on the back right bottom corner of the phone.
    • Put the pry tool or your fingertip inside the small gap on the bottom right of the back of the phone and pop up the cover.
    • Continue to go around the phone until the cover is completely off the back of the pull and put it aside.
  2. ZTE Maven 3 Motherboard Replacement, Battery: étape 2, image 1 de 3 ZTE Maven 3 Motherboard Replacement, Battery: étape 2, image 2 de 3 ZTE Maven 3 Motherboard Replacement, Battery: étape 2, image 3 de 3
    • Locate the battery in the middle of the back of the phone.
    • Push in and up on the battery to remove it from its slot.
    • Put the battery aside.
  3. ZTE Maven 3 Motherboard Replacement, Midframe: étape 3, image 1 de 1
    • Use a Phillips #00 screwdriver to remove twelve 2 mm screws along the back outer edges of the phone.
  4. ZTE Maven 3 Motherboard Replacement: étape 4, image 1 de 1
    • There’s a 13th 2 mm screw with a lock sticker over it on the bottom right corner. Insert the #00 Phillips screwdriver in the middle, breaking the sticker, and take the screw out.
  5. ZTE Maven 3 Motherboard Replacement: étape 5, image 1 de 2 ZTE Maven 3 Motherboard Replacement: étape 5, image 2 de 2
    • Slide the pry tool into the middle of the connection between the screen and the back of the phone.
    • Once in, slide the pry tool around the phone, separating the screen and the back of the phone.
    • The detached piece is the midframe, and you can place it aside when detached.
  6. ZTE Maven 3 Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Use the Phillips #00 screwdriver and remove the four 2 mm screws that are located around the edges.
  7. ZTE Maven 3 Motherboard Replacement: étape 7, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Please locate the black wire that’s attached to gold plates on the left side of the device.
    • Using a pair of tweezers, carefully grab the black wire and detach it, then remove it.
  8. ZTE Maven 3 Motherboard Replacement: étape 8, image 1 de 2 ZTE Maven 3 Motherboard Replacement: étape 8, image 2 de 2
    • Using the tweezers, carefully detach the six ribbon cables also located along the edges.
    • 2 adhesive ribbon cables (green circles).
    • One ribbon cable that slides out (orange circles).
    • Three ribbon cables that pop in and out (yellow circles).
  9. ZTE Maven 3 Motherboard Replacement: étape 9, image 1 de 3 ZTE Maven 3 Motherboard Replacement: étape 9, image 2 de 3 ZTE Maven 3 Motherboard Replacement: étape 9, image 3 de 3
    • You will also have to detach the two cameras by detaching the ribbon cable using the tweezers as well. Put those off to the side.
  10. ZTE Maven 3 Motherboard Replacement: étape 10, image 1 de 2 ZTE Maven 3 Motherboard Replacement: étape 10, image 2 de 2
    • Grab the opening pick and work it into the edges of the motherboard.
    • Make sure you are firmly pushing the pick to loosen the motherboard since it is placed with adhesive.
    • Remove the motherboard and put it aside.
Emma Thiboutot
Membre depuis le 10/30/23
699 Réputation
8 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-1, Konn Fall 2023 Membre de l'équipe UMass Dartmouth, Team 3-1, Konn Fall 2023
UMASSD-KONN-F23S3G1
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 37
