Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
If the camera seems cracked and/or not functioning, this is a quick guide on how to remove the existing camera.
Pièces
Aucune pièce spécifiée.
  1. Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail. Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail. Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
    • Pry open back cover of the device from the crease at the bottom left corner with an opening tool or fingernail.
  2. Remove all 16 screws with a J000 screwdriver. Remove all 16 screws with a J000 screwdriver.
    • Remove all 16 screws with a J000 screwdriver.
  3. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  4. Remove the battery with an opening tool or fingernail. Remove the battery with an opening tool or fingernail. Remove the battery with an opening tool or fingernail.
    • Remove the battery with an opening tool or fingernail.
  5. Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device. Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device. Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
    • Gently pry open the device body by tugging from the inside out, be sure to pull up and away from device.
  6. Once body is removed, back-facing camera is placed at the top left corner of device. Using an opening tool, pull up the tab of the camera wire ribbon. Using an opening tool, pull up the tab of the camera wire ribbon.
    • Once body is removed, back-facing camera is placed at the top left corner of device.
    • Using an opening tool, pull up the tab of the camera wire ribbon.
  7. Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently. Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently. Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
    • Using the blunt-nose tweezers, tug at the camera gently, switching sides to remove adhesive little by little, pull camera out gently.
Julian Mendoza
Membre depuis le 21/09/2018
722 Réputation
5 tutoriels rédigés
Équipe
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 119
