Introduction
How to remove the screen for the ZTE ZMAX Z970. Removing the screen is easiest with an iOpener which requires a microwave.
Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
  • Insert a fine point tool into the hole on the top left side of the phone to remove the SIM and SD card trays.
  • Pull out the trays.
Ajouter un commentaire
Insert a plastic opening tool into the groove between the phone’s back cover and casing.
  • Insert a plastic opening tool into the groove between the phone’s back cover and casing.
  • Move the plastic opening tool along the edges of the phone to unclip the two pieces.
  • Remove the ten 1.2mm screws with a Phillips #000 screwdriver.
  • Remove the mid frame with the plastic opening tool.
  • Disconnect the battery from the motherboard.
  • Wedge a spudger underneath the battery and gently pry upwards to remove the battery.
  • Once free from the glue, remove from device.
  • The glue holding down the battery is strong so work slow and cautiously to avoid starting a fire.
  • Heat up the iOpener for 30 seconds and place on top of the phone for 2 minutes.
  • Wedge the opening picks into all the corners of the phone and lift until the screen comes off.
Ismail Jhaveri
Membre depuis le 15/02/2018
135 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team S17-G3, Boczar Spring 2018 Membre de l'équipe USF Tampa, Team S17-G3, Boczar Spring 2018
USFT-BOCZAR-S18S17G3
3 membres
5 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 69
Total : 229
