Aller au contenu principal
ZTE ZMax Pro Back Panel Assembly Replacement
Ce dont vous avez besoin
  1. ZTE ZMax Pro Back Panel Assembly Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Back Panel Assembly Replacement: étape 2, image 1 de 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Back Panel Assembly Replacement: étape 3, image 1 de 2 ZTE ZMax Pro Back Panel Assembly Replacement: étape 3, image 2 de 2
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Back Panel Assembly Replacement: étape 4, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Back Panel Assembly Replacement: étape 5, image 1 de 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Back Panel Assembly Replacement: étape 6, image 1 de 2 ZTE ZMax Pro Back Panel Assembly Replacement: étape 6, image 2 de 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Back Panel Assembly Replacement: étape 7, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Back Panel Assembly Replacement: étape 8, image 1 de 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
5 autres ont terminé cette réparation.
Mihir Deshmukh
Membre depuis le 04/18/18
405 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 membres
16 tutoriels rédigés
Un commentaire
When I tried this at step 8 the screen peeled off instead of the top cover. Ruined my phone.
Solomon Martinez - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 6
Total : 855
