Aller au contenu principal
ZTE ZMax Pro Charging Port Replacement
Ce dont vous avez besoin
  1. ZTE ZMax Pro Charging Port Replacement, Back Panel Assembly: étape 1, image 1 de 1
    • Flip the phone over so that the back panel of the phone is facing up.
    • Wedge the plastic opening tool between the black outer panel and the silver side panel.
    • Push down on the plastic opening tool to separate the back panel from the rest of the phone.
    • Continue to do this around all sides of the phone until the back panel has popped all the way off.
    • Removing the back panel may make loud popping noises which is normal.
  2. ZTE ZMax Pro Charging Port Replacement: étape 2, image 1 de 1
    • Using your fingers, slide the SIM card all the way out of the phone.
  3. ZTE ZMax Pro Charging Port Replacement: étape 3, image 1 de 2 ZTE ZMax Pro Charging Port Replacement: étape 3, image 2 de 2
    Outil utilisé dans cette étape :
    • Remove the yellow Kapton tape by using the tweezers to peel it up and away from the device.
  4. ZTE ZMax Pro Charging Port Replacement: étape 4, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the two 3.0 mm screws located near the top of the phone, next to the rear camera.
  5. ZTE ZMax Pro Charging Port Replacement: étape 5, image 1 de 1
    • Remove the fingerprint sensor flex cable, using the plastic opening tool to lift it out.
  6. ZTE ZMax Pro Charging Port Replacement: étape 6, image 1 de 2 ZTE ZMax Pro Charging Port Replacement: étape 6, image 2 de 2
    • Using the tweezers, peel back the yellow Kapton tape located on the right side of the phone.
  7. ZTE ZMax Pro Charging Port Replacement: étape 7, image 1 de 1
    • Using the Phillips #00 screwdriver, remove the 15, 3.0 mm rear panel screws located around the perimeter of the phone.
  8. ZTE ZMax Pro Charging Port Replacement: étape 8, image 1 de 1
    • Flip the phone over so that the screen is facing up.
    • Wedge the plastic opening tool between the screen and the rear panel.
    • Push up on the opening tool to separate the panel from the phone.
    • Continue to do this around the entire phone until the rear panel is no longer connected to the device.
    • The rear case and screen are fastened tightly to each other. It might help to use the picks as wedges to keep the case and screen separated as you run the opening tool along the edges.
  9. ZTE ZMax Pro Charging Port Replacement, Charging Port: étape 9, image 1 de 1
  10. ZTE ZMax Pro Charging Port Replacement: étape 10, image 1 de 2 ZTE ZMax Pro Charging Port Replacement: étape 10, image 2 de 2
    • Use tweezers to peel off the tape at the bottom of the phone.
  11. ZTE ZMax Pro Charging Port Replacement: étape 11, image 1 de 1
    • Wedge the plastic opening tool under the charging port board at the bottom of the phone.
    • Push down on the plastic opening tool so the board pulls away from the phone.
    • Continue to do this around the charging port board until it comes all the way off the phone.
    • The board is glued to the case so make sure to work around all edges to ease removal. Trying to pull it away from one edge can cause damage to the board.
    • After removing the charging port, the adhesive will not have as strong of a hold on the new charging port. This should not be an issue. However, if the adhesive strength is negligible, you can consider buying adhesive and applying it before inserting the new charging port.
11 autres ont terminé cette réparation.
Nicholas Leacox
Membre depuis le 04/18/18
1 739 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team S17-G3, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G3
4 membres
16 tutoriels rédigés
11 commentaires
Very nice BUT where do you get the replacement charging port?
Anthony Kearns - Réponse
Where can I bye the parts
John Anderson - Réponse
“Buy” as in purchase not “Bye” as in see you later.
Thomas Heward - Réponse
How much is it cost to fix it
anna lightsey - Réponse
My charging port was 5.79 with free shipping at
James T. -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 5
Total : 7,946
