Aller au contenu principal
Zeal Optics iON Viewfinder Lens Replacement
Ce dont vous avez besoin
  1. Zeal Optics iON Viewfinder Lens Replacement, Lens: étape 1, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement, Lens: étape 1, image 2 de 2
    • In the next few steps, you will be releasing the clips that hold the lens in place. Do not try to completely remove the lens until all the clips have been released.
    • Hold the iON in your hands with your thumbs on the clips next to the middle of the lens.
    • Pull the rubber housing apart to release the first two clips.
  2. Zeal Optics iON Viewfinder Lens Replacement: étape 2, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 2, image 2 de 2
    • Grab the inside of the plastic nose rest with your thumb and index finger.
    • Rotate the nose rest upwards until you feel that it is free from the lens.
  3. Zeal Optics iON Viewfinder Lens Replacement: étape 3, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 3, image 2 de 2
    • Rotate the device 180 degrees.
    • Grab the top of the goggle frame that holds the camera assembly.
    • Rotate the frame outwards until you feel that the clips inside it are free.
  4. Zeal Optics iON Viewfinder Lens Replacement: étape 4, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 4, image 2 de 2
    • While firmly holding the goggles with the palm of one hand, grab the top right corner of the frame and rotate it away from the lens.
  5. Zeal Optics iON Viewfinder Lens Replacement: étape 5, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 5, image 2 de 2
    • The lens should now be barely attached to the frame. If it still feels firmly attached, repeat any necessary steps to free the clips.
    • While holding the goggles in one hand, use the other to grab the lens from opposite ends, and rotate it out of the housing and away from any remaining clips.
  6. Zeal Optics iON Viewfinder Lens Replacement, Camera Assembly: étape 6, image 1 de 1
    • Remove the four 7.1 mm Phillips screws securing the camera housing to the goggle frame.
  7. Zeal Optics iON Viewfinder Lens Replacement: étape 7, image 1 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 7, image 2 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 7, image 3 de 3
    • Peel back the rubber battery cover from the inner left side of the frame.
    • While firmly holding the battery cover, pull the bottom of the strap mount cover up and off of the frame
  8. Zeal Optics iON Viewfinder Lens Replacement: étape 8, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 8, image 2 de 2
    • Once the bottom is free, continue pulling to free the top of the strap mount cover from the frame.
  9. Zeal Optics iON Viewfinder Lens Replacement: étape 9, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 9, image 2 de 2
    • Pull the battery out of its recess in the frame.
    • The battery is connected to the entire camera assembly and cannot be completely removed by itself.
  10. Zeal Optics iON Viewfinder Lens Replacement: étape 10, image 1 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 10, image 2 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 10, image 3 de 3
    • Peel the rubber keypad cover up from the inner right side of the frame.
    • While firmly holding the keypad cover, pull the top of the strap mount cover up and off of the frame
  11. Zeal Optics iON Viewfinder Lens Replacement: étape 11, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 11, image 2 de 2
    • Once the bottom is free, continue pulling to free the bottom of the strap mount cover from the frame.
  12. Zeal Optics iON Viewfinder Lens Replacement: étape 12, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 12, image 2 de 2
    • Hold the strap mount cover away from the frame and remove the keypad.
  13. Zeal Optics iON Viewfinder Lens Replacement: étape 13, image 1 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 13, image 2 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 13, image 3 de 3
    • Grab the viewfinder housing and pull it out of its recess.
    • Just like the battery, the viewfinder housing is connected to the rest of the camera assembly and cannot be removed by itself.
  14. Zeal Optics iON Viewfinder Lens Replacement: étape 14, image 1 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 14, image 2 de 3 Zeal Optics iON Viewfinder Lens Replacement: étape 14, image 3 de 3
    • Place one of your hands near the center of the frame with your thumb next to the camera housing.
    • With your other hand, grab the camera housing and pull it up and out of the frame.
  15. Zeal Optics iON Viewfinder Lens Replacement: étape 15, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 15, image 2 de 2
    • Remove the viewfinder assembly by pulling it through the opening in the top of the frame.
  16. Zeal Optics iON Viewfinder Lens Replacement: étape 16, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 16, image 2 de 2
    • In the same manner described above, remove the battery from the frame.
  17. Zeal Optics iON Viewfinder Lens Replacement, Viewfinder Lens Assembly: étape 17, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement, Viewfinder Lens Assembly: étape 17, image 2 de 2
    • Remove the two 7.5 mm Phillips screws on the front of the viewfinder housing.
    • Flip the viewfinder housing over 180 degrees.
    • Remove the four 7.1 mm Phillips screws from the back of the viewfinder housing.
  18. Zeal Optics iON Viewfinder Lens Replacement: étape 18, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 18, image 2 de 2
    • Pull the two halves of the viewfinder housing apart.
  19. Zeal Optics iON Viewfinder Lens Replacement: étape 19, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 19, image 2 de 2
    • Use the tip of a spudger to flip up the retaining flap on the LCD ribbon cable ZIF connector.
    • Be sure to pry up on the hinged flap, not the connector itself.
  20. Zeal Optics iON Viewfinder Lens Replacement: étape 20, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 20, image 2 de 2
    • Use the tip of a spudger to push out the retaining clip on the viewfinder backlight ribbon cable ZIF connector.
  21. Zeal Optics iON Viewfinder Lens Replacement: étape 21, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 21, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Using your fingers or tweezers, gently pull out the backlight ribbon cable from its connector on the button board.
  22. Zeal Optics iON Viewfinder Lens Replacement: étape 22, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 22, image 2 de 2
    • Using your fingers or tweezers, remove the LCD ribbon cable from its connector on the button board.
  23. Zeal Optics iON Viewfinder Lens Replacement: étape 23, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement: étape 23, image 2 de 2
    • Remove the viewfinder lens assembly from the viewfinder housing.
  24. Zeal Optics iON Viewfinder Lens Replacement, LCD Assembly: étape 24, image 1 de 2 Zeal Optics iON Viewfinder Lens Replacement, LCD Assembly: étape 24, image 2 de 2
    • Use your thumbs to lift the tabs holding the viewfinder lens to the LCD assembly.
    • Pull the viewfinder lens off of the viewfinder LCD.
  25. Zeal Optics iON Viewfinder Lens Replacement, Viewfinder Lens: étape 25, image 1 de 3 Zeal Optics iON Viewfinder Lens Replacement, Viewfinder Lens: étape 25, image 2 de 3 Zeal Optics iON Viewfinder Lens Replacement, Viewfinder Lens: étape 25, image 3 de 3
    • Remove the rubber O-ring from the viewfinder lens.
    • The viewfinder lens remains.
Eric Flores
Membre depuis le 07/31/12
128 Réputation
9 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 1,194
