Introduction
This is a guide for replacing the motherboard of your Zeki device.
First, to reach the motherboard, remove the plastic backing, then the battery, and lastly the camera.
After replacing the motherboard, the device will need to be reassembled in the opposite order.
Ce dont vous avez besoin
Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
Place the tablet down so that the screen is facing away from you.
Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
Gently work your way around the perimeter of the tablet's edge.
2 autres ont terminé cette réparation.
