Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Zeki TBQG884B Motherboard Replacement
Ce dont vous avez besoin
    1. Zeki TBQG884B Motherboard Replacement, Rear Case: étape 1, image 1 de 2 Zeki TBQG884B Motherboard Replacement, Rear Case: étape 1, image 2 de 2
      • Remove the two screws from the end of the device where the ports are located using a Phillips #1 screwdriver.
      Demander à FixBot
      Ajouter un commentaire
    2. Zeki TBQG884B Motherboard Replacement: étape 2, image 1 de 1
      • Place the tablet down so that the screen is facing away from you.
      • Insert the tip of your opening tool into the small gap between the gray and white plastic covering. Pry it open and you should hear the clips opening up.
      • Gently work your way around the perimeter of the tablet's edge.
      Demander à FixBot
    3. Zeki TBQG884B Motherboard Replacement: étape 3, image 1 de 2 Zeki TBQG884B Motherboard Replacement: étape 3, image 2 de 2
      • Remove the back cover
      • Remove any tape on the speaker and detach the speaker from the back plate.
      • The speaker is connected to the motherboard by two soldered wires. Don't break them when you remove the speaker.
      Demander à FixBot
    1. Zeki TBQG884B Motherboard Replacement, Motherboard: étape 4, image 1 de 1
      • Disconnect the Wi-Fi antenna cable from the motherboard.
      Demander à FixBot
    2. Zeki TBQG884B Motherboard Replacement: étape 5, image 1 de 1
      • Using the Phillips #1 screwdriver, remove the three screws from the motherboard..
      Demander à FixBot
    3. Zeki TBQG884B Motherboard Replacement: étape 6, image 1 de 1
      • Open the ZIF connector. Then, remove the ribbon that connects the motherboard and the screen.
      Demander à FixBot
    4. Zeki TBQG884B Motherboard Replacement: étape 7, image 1 de 1
      • Disconnect the other ZIF connector on the opposite side of the motherboard.
      Demander à FixBot
    5. Zeki TBQG884B Motherboard Replacement: étape 8, image 1 de 1
      • Remove the motherboard and now reinsert all connectors into a new motherboard.
      • In order to disconnect the battery and speaker wires from the motherboard, soldering is required. Be cautious as the soldering iron is hot.
      Demander à FixBot
2 autres ont terminé cette réparation.
Linlin Cai
Membre depuis le 09/16/15
317 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 1-3, Harley Fall 2015 Membre de l'équipe IUPUI, Team 1-3, Harley Fall 2015
IUPUI-HARLEY-F15S1G3
5 membres
60 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 26
30 derniers jours : 62
Total : 952
