Aller au contenu principal
Zenbre SoundBank Z3 Battery Replacement
Ce dont vous avez besoin
  1. Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: étape 1, image 1 de 2 Zenbre SoundBank Z3 Battery Replacement, Bottom Cover: étape 1, image 2 de 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Battery Replacement: étape 2, image 1 de 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Battery Replacement: étape 3, image 1 de 2 Zenbre SoundBank Z3 Battery Replacement: étape 3, image 2 de 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: étape 4, image 1 de 3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: étape 4, image 2 de 3 Zenbre SoundBank Z3 Battery Replacement, Motherboard Cover: étape 4, image 3 de 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Battery Replacement, Battery: étape 5, image 1 de 2 Zenbre SoundBank Z3 Battery Replacement, Battery: étape 5, image 2 de 2
    • Remove the battery from the holder. It may be difficult the first time.
    • Use a spudger between the battery and speaker wall to loosen it from its surroundings.
    • If the battery is punctured, leaking, or bloated/puffy, it may be hazardous and should be properly disposed of.
  6. Zenbre SoundBank Z3 Battery Replacement: étape 6, image 1 de 2 Zenbre SoundBank Z3 Battery Replacement: étape 6, image 2 de 2
    • Remove the pressure-fitted foam from the slot by hand.
    • Unravel and remove foam from the wires.
    • When reassembling, the foam can be re-wrapped if care is taken when handling it.
  7. Zenbre SoundBank Z3 Battery Replacement: étape 7, image 1 de 1
    • Using a soldering iron, remove the leads, separating the battery from motherboard.
    • Follow this guide to help you remove the wires from the motherboard if you are unfamiliar with soldering.
3 autres ont terminé cette réparation.
Cherian Thomas
Membre depuis le 03/25/16
334 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 membres
8 tutoriels rédigés
3 commentaires
Thank you for providing battery replacement instructions for the ZENGRE BlueTooth speaker system. They are very helpful.
Michael Coleman - Réponse
Bendiciones. con que batería la reemplazaste? podrías enviarme un link para comprarlo, desde ya muchas gracias
Alier Obed Jaenz Rivas -
MUCHAS GRACIAS!!!!
Sin embargo hubiese sido exelente pudiese mostrarse los tipos de batería con los cuales se puede reemplazar.
Alier Obed Jaenz Rivas - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 12
Total : 4,577
