Aller au contenu principal
Zenbre SoundBank Z3 Speaker Grill Replacement
Ce dont vous avez besoin
  1. Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: étape 1, image 1 de 2 Zenbre SoundBank Z3 Speaker Grill Replacement, Bottom Cover: étape 1, image 2 de 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Grill Replacement: étape 2, image 1 de 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Grill Replacement: étape 3, image 1 de 2 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 3, image 2 de 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: étape 4, image 1 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: étape 4, image 2 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Motherboard Cover: étape 4, image 3 de 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: étape 5, image 1 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: étape 5, image 2 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement, Speaker Grill: étape 5, image 3 de 3
    • Remove the three silver Phillips screws from the plastic ring that holds the speaker in place.
    • Be careful not to rip out the speaker while taking out the screws
    • The same steps can be done on the other side of the speaker
  6. Zenbre SoundBank Z3 Speaker Grill Replacement: étape 6, image 1 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 6, image 2 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 6, image 3 de 3
    • First, remove the speaker from the motherboard, then remove the ring that held the speaker in place.
    • These are the joints that need to be soldered. Follow this guide link to help you remove the wires from the motherboard.
    • How To Solder and Desolder Connections
  7. Zenbre SoundBank Z3 Speaker Grill Replacement: étape 7, image 1 de 2 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 7, image 2 de 2
    • With the plastic ring removed, the speaker should slide out easily.
    • Be careful not remove other components in the speaker
    • This will expose the speaker grill
  8. Zenbre SoundBank Z3 Speaker Grill Replacement: étape 8, image 1 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 8, image 2 de 3 Zenbre SoundBank Z3 Speaker Grill Replacement: étape 8, image 3 de 3
    • Now that the speaker has been removed, the plastic grill should be visible.
    • With a little bit of force they can be pushed out.
2 autres ont terminé cette réparation.
Équipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 4
Total : 537
