Aller au contenu principal
Zenbre SoundBank Z3 Speaker Replacement
Ce dont vous avez besoin
  1. Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: étape 1, image 1 de 2 Zenbre SoundBank Z3 Speaker Replacement, Bottom Cover: étape 1, image 2 de 2
    • Power off the SoundBank Z3.
    • Turn over the device.
    • Peel the silicone feet up to remove.
    • No extra adhesive is needed to reapply the feet as long as the sticky side is not touched.
  2. Zenbre SoundBank Z3 Speaker Replacement: étape 2, image 1 de 1
    • Remove all eight of the 11 mm Phillips screws from the bottom of the device.
  3. Zenbre SoundBank Z3 Speaker Replacement: étape 3, image 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: étape 3, image 2 de 2
    • Remove the bottom panel speaker using an iFixit opening tool.
  4. Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: étape 4, image 1 de 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: étape 4, image 2 de 3 Zenbre SoundBank Z3 Speaker Replacement, Motherboard Cover: étape 4, image 3 de 3
    • Remove the four 4.5 mm silver Phillips screws that secure the plastic panel covering the motherboard.
    • Remove the plastic panel.
  5. Zenbre SoundBank Z3 Speaker Replacement, Speakers: étape 5, image 1 de 2 Zenbre SoundBank Z3 Speaker Replacement, Speakers: étape 5, image 2 de 2
    • Remove the three screws that are holding the speaker down.
    • Be careful not to rip out the speaker while taking out the screws.
  6. Zenbre SoundBank Z3 Speaker Replacement: étape 6, image 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: étape 6, image 2 de 2
    • Desolder the speaker joints from the motherboard. Follow this How To Solder guide for help with desoldering.
  7. Zenbre SoundBank Z3 Speaker Replacement: étape 7, image 1 de 2 Zenbre SoundBank Z3 Speaker Replacement: étape 7, image 2 de 2
    • Remove the speaker from the motherboard.
    • Remove the speaker ring.
    • Be careful not to remove other components in the speaker.
    • Repeat Steps 5-7 with the other speaker.
Cherian Thomas
Membre depuis le 03/25/16
334 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 3-2, Bhusal Spring 2016 Membre de l'équipe UMass Dartmouth, Team 3-2, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G2
5 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 12
Total : 471
