Aller au contenu principal
Zoll Impact Uni-Vent 731 Battery Compartment Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Zoll Impact Uni-Vent 731 Battery Compartment Replacement, Battery Compartment Kit: étape 1, image 1 de 1
    • Remove the battery compartment cover by unscrewing the (4) Phillips 6-32 X 5/16 screws. This is indicated in red with the number 1.
    • Page 25.
  2. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 2, image 1 de 2 Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 2, image 2 de 2
    • Remove the battery by unscrewing the (4)Phillips 6-32 X 2 ¼ screws and detaching the plug from its locking latch. This is indicated in the second picture in blue with the number 2.
    • Page 25.
  3. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 3, image 1 de 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
    • Page 25.
  4. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 4, image 1 de 1
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) Phillips 6-32 X 5/16 screws provided.
    • Page 25.
  5. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 5, image 1 de 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) Phillips 6-32 X 2 ¼ screws. This is indicated in blue with the number 5.
    • Page 25.
  6. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 6, image 1 de 1
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X5/16 screws. This is indicated in red with the number 6.
    • Page 25.
  7. Zoll Impact Uni-Vent 731 Battery Compartment Replacement: étape 7, image 1 de 1
    • Perform HiPot Testing then perform Functional Test using the RCS to verify the replacement is working properly.
    • Page 25.
Michaela Fromm
Membre depuis le 05/04/20
150 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 5
Total : 248
