Aller au contenu principal
Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement
Matériel médical
Ni iFixit ni ce tutoriel de réparation ne sont approuvés par ou affiliés au fabricant de ce dispositif médical.
Ce dont vous avez besoin
  1. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement, SPM Vent Kit: étape 1, image 1 de 1
    • Loosen but do not remove the(4) 8-32 X 3 screws on the outer air intake.
  2. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 2, image 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 2, image 2 de 2
    • Loosen and remove the (2) 10-32 Keps nuts and the (4) 6-32 X 2 screws. Remove the back case by lifting from the ventilator.
  3. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 3, image 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 3, image 2 de 2
    • Remove the (2) 4-40 X ¼ screws on the Dovetail Mounting Bracket and disconnect the ribbon cable on the PIM PCB by simultaneously applying pressure on the two locking “ears”.
  4. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 4, image 1 de 1
    • Flip the ventilator over and remove the front case assembly by lifting it straight up away from the ventilator module.
  5. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 5, image 1 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 5, image 2 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 5, image 3 de 3
    • Remove the battery compartment cover by unscrewing the (4) 6-32 X 5/16 screws.
  6. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 6, image 1 de 1
    • Remove the battery by unscrewing the (4) 6-32 X 2 ¼ screws and detaching the plug from its lockinglatch.
  7. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 7, image 1 de 1
    • Unscrew the (4) 6-32 X 5/16 Phillips screws to remove the damaged battery compartment case.
  8. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 8, image 1 de 1
    • Loosen and remove the (2) 4-40 X 1 ¼ Screws and nylon spacers supporting the Power Input assembly unto the chassis
  9. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 9, image 1 de 1
    • Loosen and remove the (2) 6-32 X ¼ screws holding the chassis to the dovetail mounting bracket and remove the SPO2 insulator. Loosen and remove the (2) 8-32 X ¼ screws holding the chassis to the vent module
  10. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 10, image 1 de 1
    • Insert screwdriver through the holes on the chassis to loosen and remove the (2) 6-32 x 5/16 screws holding the chassis to the vent module.
  11. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 11, image 1 de 1
    • Lift the damaged chassis from the ventilator module.
  12. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 12, image 1 de 1
    • Disconnect the Power Input cable from the PIM PCB by pressing on the locking latch and pulling the cable straight up from the connector.
  13. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 13, image 1 de 1
    • Remove the PIM PCB by loosening the (5) 4-40 X 5/16 screws.
  14. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 14, image 1 de 1
    • Remove the Dovetail stabilizer bracket by loosening and removing the (2) 6-32 x ¼ and the (2) 4-40 X ¼ screws.
  15. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 15, image 1 de 1
    • Install the dovetail stabilizer bracket ontothe new SPM assembly by tightening the (2) 6-32 X ¼ and (2) 4-40 X ¼ screws.
  16. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 16, image 1 de 1
    • Secure the PIM Board to the new SPM with the (5) 4-40 x 5/16 screws.
  17. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 17, image 1 de 1
    • Secure the chassis to the vent module using the (2) 6-32 X ¼ screws with SPO2 insulator, the (2) 8-32 X ¼ and the (2) 6-32 x 5/16 screws.
  18. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 18, image 1 de 1
    • Secure the Power Input assembly to the Chassis using the (2) spacers and (2) 4-40 X 1 ¼ screws. Do not over-tighten the screws.
  19. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 19, image 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 19, image 2 de 2
    • Rotate battery compartment to mate with upper and lower case cutouts and press firmly into place. Secure with (4) 6-32 X 5/16 screws provided
  20. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 20, image 1 de 1
    • Re-assemble the battery by connecting its cable to the connector (pull on cable to insure it is locked in place) then tightening the (4) 6-32 X 2 ¼ screws.
  21. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 21, image 1 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 21, image 2 de 3 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 21, image 3 de 3
    • Re-assemble the battery compartment cover by tightening the (4) 6-32 X 5/16 screws.
  22. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 22, image 1 de 1
    • Place the front case assembly over the vent module and tighten the (2) 4-40 X ¼ screws unto the dovetail mounting bracket. Reconnect the ribbon cable unto the PIM PCB. Make sure the two locking “ears” lock into position.
  23. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 23, image 1 de 1
    • Attach the back case to the vent module and align cover with handle, air intake housing and dovetail mounting studs. Insert and tighten the included (2) 10-32 Keps nuts and the (4) 6-32 X 2” screws.
  24. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 24, image 1 de 2 Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 24, image 2 de 2
    • Tighten the (4) 8-32 X 3 screws on the outer air intake.
  25. Zoll Impact Uni-Vent 731 SPM Vent Kit Replacement: étape 25, image 1 de 1
    • Perform HiPot Testing then perform Calibration and Functional Test using the RCS.
Brandon Drury
Membre depuis le 05/04/20
391 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S1-G5, Zimmerman Spring 2020 Membre de l'équipe Cal Poly, Team S1-G5, Zimmerman Spring 2020
CPSU-ZIMMERMAN-S20S1G5
5 membres
5 tutoriels rédigés
Un commentaire
Hi
What is the service passcode to reset the PM clock?
fayezhmc - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 293
