Introduction
Outline what you are going to teach someone how to do.
  1. Place the device so the display is down.
    • Place the device so the display is down.
  2. Remove the battery cover, pressing down on the tabs and sliding.
    • Remove the battery cover, pressing down on the tabs and sliding.
  3. Unscrew the two (2)  #00, 10 mm screws located below the mic on the back cover
    • Unscrew the two (2) #00, 10 mm screws located below the mic on the back cover
  4. Carefully pry up the top end of the back cover using one finger
    • Carefully pry up the top end of the back cover using one finger
  5. %Livraison gratuite pour toute commande supérieure à 100,00 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
    Vous avez déjà réparé quelque chose ? Vous êtes un génie.
    Partagez votre réparation avec le hashtag #ImAGenius
    Nous sommes tous des génies
  6. Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
    • Remove the back plate by using a plastic removal tool to pry the back cover up around the edges.
  7. De-solder at terminal point one.
    • De-solder at terminal point one.
  8. De-solder at the second terminal point.
    • De-solder at the second terminal point.
  9. Remove the faulty terminals Remove the faulty terminals
    • Remove the faulty terminals
  10. Place new lead in at point one and re-solder at the point.
    • Place new lead in at point one and re-solder at the point.
  11. Place second lead at point 2 and re-solder.
    • Place second lead at point 2 and re-solder.
To Re-construct device, perform these steps in reverse order.
Alex
Membre depuis le 28/10/2013
758 Réputation
5 tutoriels rédigés
Caution is needed with step 5. My backside broke off using a spudger to attempt to remove.
Joe Vaughan - Réponse
Mine has third screw under the serial-number sticker.
halluciana - Réponse
Can anyone advise where to find replacement terminals? My zoom h1 has bad corrosion of its battery terminals and I would like to follow this guide to fix them! Thanks!
Dylan St John - Réponse
My zoom h1 is just dead with no reason , can i fix my zoom h1 with this guide ??
Jas Jes! - Réponse
Where can i find the replacement battery terminals?
krissie_prime - Réponse
Voir les statistiques:
Dernières 24 heures : 1
7 derniers jours : 10
30 derniers jours : 56
Total : 3,819
