Aller au contenu principal
Zoom H6 Handy Recorder Screen Replacement
Ce dont vous avez besoin
  1. Zoom H6 Handy Recorder Screen Replacement, Case: étape 1, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement, Case: étape 1, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement, Case: étape 1, image 3 de 3
    • Place device face up and pry off the four knobs using the flat end of the plastic opening tool.
    • You may need to stabilize the device with the other hand.
  2. Zoom H6 Handy Recorder Screen Replacement: étape 2, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 2, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 2, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • With device facedown, lift the four rubber feet from the device using tweezers or fingernails.
  3. Zoom H6 Handy Recorder Screen Replacement: étape 3, image 1 de 2 Zoom H6 Handy Recorder Screen Replacement: étape 3, image 2 de 2
    • With device still facedown, unscrew six (PH #1), 9mm screws; two located in center of back side of device right above the battery cover, and four under the rubber feet.
    • An electronics screwdriver small enough to fit in hole (4mm diameter), but long enough to reach the screws (at least 2cm) will be required to unscrew the screws.
  4. Zoom H6 Handy Recorder Screen Replacement: étape 4, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 4, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 4, image 3 de 3
    • With the bottom of the device on a table, lift the top of the device and gently place it aside.
  5. Zoom H6 Handy Recorder Screen Replacement, Screen: étape 5, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement, Screen: étape 5, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement, Screen: étape 5, image 3 de 3
    • Unscrew three (PH #1), 7 mm screws (two on right side of display and one on the bottom left).
  6. Zoom H6 Handy Recorder Screen Replacement: étape 6, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 6, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 6, image 3 de 3
    • Lift the button board gently to reveal the ribbon connector.
  7. Zoom H6 Handy Recorder Screen Replacement: étape 7, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 7, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 7, image 3 de 3
    • Using a plastic opening tool, unlatch the clip and carefully unplug the ribbon connector from the device .
    • Set the button board aside.
  8. Zoom H6 Handy Recorder Screen Replacement: étape 8, image 1 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 8, image 2 de 3 Zoom H6 Handy Recorder Screen Replacement: étape 8, image 3 de 3
    • Use a plastic opening tool to lift the screen from the the backing.
    • Replace the screen.
    • Make sure to not touch the screen directly as it will leave smudges.
    • If need be, the ribbon for the screen could also be replaced during this step.
10 autres ont terminé cette réparation.
William D'Arrigo
Membre depuis le 02/14/18
281 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team S5-G2, Eyestone Spring 2018 Membre de l'équipe USF Tampa, Team S5-G2, Eyestone Spring 2018
USFT-EYESTONE-S18S5G2
4 membres
10 tutoriels rédigés
26 commentaires
Hello.
I-m so glad to find this tutorial.
I just have one question, do you know where can i get a LCD screen for my zoom H6. I live in France, i’ve been looking for it on the web but nothing. Thankyou for your help.
pernimatic - Réponse
Hey friend, check bellow.
Hadrien -
Hi, I have the same question, where can I get the display? in the zoom support they do not respond. Thanks
Jonathan Race - Réponse
Hi guys, same problem. I just found this, could it be this screen ? http://www.hktdc.com/suppliers-products/...
Hadrien - Réponse
Hi guys, I found my H6 screen here : https://shop.audiotronic.fr/fr/ The team is very nice and helpful, don’t hesitate to call them.
Hadrien - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 26
30 derniers jours : 140
Total : 8,384
