Aller au contenu principal
Zoomer Dino Boomer Back Button Replacement
Ce dont vous avez besoin
  1. Zoomer Dino Boomer Back Button Replacement, Back Cover: étape 1, image 1 de 1
    • Power off Zoomer Dino Boomer before disassembly.
    • Remove the eight 9.3mm Phillips #1 screws.
  2. Zoomer Dino Boomer Back Button Replacement: étape 2, image 1 de 2 Zoomer Dino Boomer Back Button Replacement: étape 2, image 2 de 2
    • Turn dinosaur over and hold upright.
    • Use the spudger to pry apart the back cover from the remainder of the Zoomer Dino Boomer.
    • Be gentle while removing the back cover. The back cover of the Zoomer Dino Boomer is still connected to the electronic system by a wire.
  3. Zoomer Dino Boomer Back Button Replacement: étape 3, image 1 de 3 Zoomer Dino Boomer Back Button Replacement: étape 3, image 2 de 3 Zoomer Dino Boomer Back Button Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Disconnect the wire that connects the back cover of the dino to the main circuit board by carefully pulling on the orange wire connector with tweezers.
    • Remove back cover.
    • If you are having difficulty removing the connector from its socket, push in the small tabs on the side of the connector with the tweezers. This step may take some work.
    • Do not damage the wires or circuit board.
  4. Zoomer Dino Boomer Back Button Replacement, Back Button: étape 4, image 1 de 1
    • Where the button is largest, squeeze the two white tabs together.
  5. Zoomer Dino Boomer Back Button Replacement: étape 5, image 1 de 1
    • Push in the white circular piece between these tabs as far as it will go.
  6. Zoomer Dino Boomer Back Button Replacement: étape 6, image 1 de 2 Zoomer Dino Boomer Back Button Replacement: étape 6, image 2 de 2
    • Where the button is smallest, squeeze the two white tabs together and press the circular tab in-between them until the button comes loose.
    • Remove the back button.
Lauren Mannix
Membre depuis le 08/29/15
398 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 16-1, Wollert Fall 2015 Membre de l'équipe USF Tampa, Team 16-1, Wollert Fall 2015
USFT-WOLLERT-F15S16G1
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 13
Total : 2,037
